PLZ HELP scrambler 500
Old 07-27-2015, 05:56 AM
Originally Posted by scram5050
hey just turned it on and put volt meter on it it droped from 12.57 to 12.40 and if i hit the throttle it would go a little lower
If you have it on the atv and running,it's not charging! Should be at 14 volts.. Check that the regulator wires are all plugged in. If they are just order the cheap regulator on ebay.This may be the main reason you're having problems?
  #32
Old 07-27-2015, 08:13 AM
scram5050's Avatar
just looked at recifire it actually has a burned pig tail connecter its toast i cant reconnect the pig tail at all if i was to buy a new one i cant connect it ither both peices r black and toast lol
  #33
Old 07-27-2015, 09:23 AM
Just simply splice in new bullet connectors on the burnt wiring to accept new regulator leads. You have to have it to keep the battery charged,so the lights will work,fan will work,etc....I've had regulators melt along with wiring also. Had to do the same thing.
  #34
Old 07-27-2015, 09:31 AM
scram5050's Avatar
can you please explain to me how to splice it ? and just to let you know its the solid yellow wire
  #35
Old 07-27-2015, 09:40 AM
  #36
Old 07-27-2015, 12:52 PM
scram5050's Avatar
where can i buy new bullete connecters
  #37
Old 07-27-2015, 12:56 PM
1ArmBandit's Avatar
auto parts store...walmart
  #38
Old 07-27-2015, 01:01 PM
scram5050's Avatar
never mind lol found some
  #39
Old 07-27-2015, 01:23 PM
user493's Avatar
Moto Psycho
I have the same cheap wiring tool in my tool box. I never even thought about spinning it around to cut the insulation better. I'll have to remember that. BTW he strips off too much insulation. I guess that's better than too little but you can only stick it so far into a butt connector on each end.
exmotocrosser
09-13-2019 06:12 AM
Matt123
09-29-2015 01:29 AM
exmotocrosser
09-26-2015 08:18 AM
Nosparkpolaris
09-20-2015 04:21 PM
1000gade
09-09-2015 03:35 PM
Quick Reply: PLZ HELP scrambler 500
