over heating
If you cleaned the radiator,that is removed it and cleaned and refilled,then probably has trapped air pockets in the system.Even if you haven't removed it that can happen. Raise the front end to where the tires are off the ground,leave the radiator cap off and let the fan cycle on and off several times. If it has any trapped air the radiator level will drop.You can also see if the coolant is circulating into the radiator. After awhile running like this you can top off the radiator and over flow bottle. Hopefully the impeller is ok. We hardly ever had thermostat problems,but not saying that one could stick and cause problems.
i didnt remove the radiator i cleaned all the fins it had a lot of dirt packed in it also the machine sat 4 5 or 6 months before i bought it . would that possible cause the thermostate to stick. and one more thing should the fan stay on after the key is off when hot because it doesnt thanks 4 the help!!
