How do I replace buttons on Drive Clutch?
Old 03-25-2003, 01:48 PM
NCScrambler's Avatar
Default How do I replace buttons on Drive Clutch?
I agree with you farmr, I don't see how the front buttons could wear out faster than the rear buttons unless there is something else going on in there. The only thing I could think of is that the Heelclicker puts alot more stress on those torque buttons, more side pressure. Not sure but it would be interesting to see this in person to see why the front buttons are wearing so quick.
Old 03-25-2003, 02:17 PM
PolarisPower500's Avatar
I think the rear buttons wear out from high torque and many miles. The front buttons, like what happened with my clutch, wore out from far too many deep swims and high heat belt slipping. The primary hates water and will need rebuilt in a short period of time. The bushings that slide on the shaft were also very worn and made lots of noise with the belt cover off. My rear clutch is very tight because my machine has low miles.
I have 6x6 amphibious ATVs over thirty years old with rear clutch buttons that look new.
Old 03-25-2003, 05:51 PM
Bubba297's Avatar
At least you guys can rebuild. The race modded stuff wears down everything fast enough you just replace the whole darn thing.
Old 03-25-2003, 09:27 PM
fullthrottle's Avatar
What will be noticed when the buttons wear out as far as performance goes? Or in other words
what are the buttons main function?
  #15
Old 03-25-2003, 09:51 PM
ftwflh's Avatar
Mainly you will hear it rattle(mine sounded like the rod was knocking)and it will not shift quite like it should.
txkevin
09-21-2015 02:02 PM
bikedad3
07-02-2015 02:15 AM
Dieseltrash
06-01-2015 06:53 AM
Polarisman1123
05-25-2015 10:07 PM
Polarisman1123
05-25-2015 10:03 PM
Quick Reply: How do I replace buttons on Drive Clutch?
