2007 Polaris trail boss 330 bogs down
New plug,check that the fuel pump is ok. If it's pumping fuel then sounds like something stopped up in the carb. All it takes is a little piece of trash in the jets.If that doesn't help,then could be a problem on that old ecm module that fails. Item #18.http://www.partzilla.com/parts/searc...GHT/parts.html Or possibly the limiter(#15) right next to it. Pull the black wire and see it that solves it. They can fault and limit in forward range.
