Quadracer threads doing well!
Old 03-23-2004, 10:46 AM
quadracer239's Avatar
Default Quadracer threads doing well!
86 lt250r
fmf pipe an silencer
bored 80 over
wiesco piston an rings
boyseen reeds
bigger main jet(2 sizes)
pro taper bars
thumb throttle off a 03 kfx400
maier plastic
graydon nerf bars
graydon front bumber
19-6-10 holeshots fr
18-9.5-8 turf tamers rear
douglas wheels
uni air filter
water pump rebuilt(all new seals)
new kick start lever (oem)
new bearing
k&k block off plate
galfer brake pads
set up to race mx
  #22
Old 03-23-2004, 11:17 AM
ProComp's Avatar
Cool post. Man, a lot of you guys have gone nuts on your quadracers.
Mines a 1985.
Bought it with a rebuilt motor (not sure how much is bored)
New Clutch
I re-did the following:
New MSR bars
Maier plastic
Recovered seat
Powdercoated rims and 12 other pieces
New Rear Tires
Rebuilt carb and put back to stock specs.
Still working out some of the bugs to get this thing to run like it should.
Clutch is giving me grief as it does not shift well.
When I put it in first gear and pull the clutch in, it does not roll as free as when it is in Neutral.
Is this normal? I have adjusted the cluch quite far pulling it in to help engagement and it has helped.
However the clutch lever is quite stiff to pull now.
Are the clutch and tranny systems in these quads pretty good?
Thanks a lot.
Brad
  #23
Old 03-23-2004, 04:48 PM
sam250's Avatar
My 86 LT250R (that I've owned since 88)
Engine rebuilt top and bottom end. Cylinder bored and head shaved .020".
Original frame got bent. Replacement frame was reinforced and gussetted. (sp?)
15" works dual rates w/ rezzies (waiting for HSD +3 arms and shock bracket - on order [img]i/expressions/face-icon-small-happy.gif[/img])
Revalved and resprung 89 rear shock.
Aaen pipe with FMF turbine core silencer.
Gibson pro peg nerfs.
Braided brake hoses.
Renthal Fat bars.
20" Bandit rears.
K&N w/ outerwear and open airbox.
14T sprocket (too tall, 13T on order)
PRM 6 pack rack
Still need:
HSD Extended A-arms and shock relocation bracket - ordered.
Front and rear plastics
Front tires
Steering stabilizer
  #24
Old 03-23-2004, 06:02 PM
800screws's Avatar
hey scarab, i noticed u have an 85-86 chain guard on a 91 engine....did it bolt right up??
  #25
Old 03-24-2004, 09:12 AM
scarab1's Avatar
800screws
I never knew it was an 85-86 chainguard. It was on there when I bought the quad. It looks factory and bolted right up w/o any mods as far as I can tell. No welded bosses or anything. My bike is in really good shape and has the original engine and frame paint on it still so, I would have noticed any mods to the cover.
Thanks for looking,
Dan
  #26
Old 03-24-2004, 09:27 AM
scarab1's Avatar
800screws
I looked at some of the 87 and up chainguards in other posts and I like the 85-86 guard better! I'm glad mine has a 85-86 on. Looks sportier....if that make sense! too many holes in the 87 and up guard.
  #27
Old 03-25-2004, 02:46 AM
Dirtyquad's Avatar
87lt500.
I MILLED AND O-RINGED THE HEAD, 185 PSI 80DEG AT 1000'
87.5 BORE, SCORCHED THE PISTON AT GLAMIS 04-14-04 TOOO LEAN AFTER PORTING
STOCK CARB BORED by ME and it didn't cost a dime
GOT RID OF FMF BACK TO STOCK PIPE-(FASTER)
PORTED. RAISED TRANSFERS .020 CUT THE HELL OUT OF EX AND OPENED INTAKE me
K&N AIR FILTER
pyramid reeds
swingarm?? not shure
FIRST QUAD FOR ME BOUGHT 10-03
LESS THAN $3300 INVESTED TOTAL AND SMOKES EXPENSIVE SHEES HAHA!!
  #28
Old 03-26-2004, 11:18 PM
lt500abuser's Avatar
hey,chromesalot we'll have to hook for some riding north of you at stonyford off of I-5 at maxwell on tuesday or thrusday coming up, it just rained up there so the dust will be down.there's still snow on mt.st.john. what's up? care to scatch off some chrome?
  #29
Old 03-27-2004, 01:11 AM
Slinger's Avatar
500R
dual exhaust
4 barrel carb
6" Holley HiRise intake
shift kit
Mallory ignition
posi trac
  #30
Old 03-27-2004, 01:18 AM
Chromezilla's Avatar
You talking to me?!?!?!?!?!?.. If so I am up for it. I will have to get directionns, but I am up for a ride 1-2 hours long. I am in Campbell. IS it much frture then that?? If you can, give me the excact address and I will go say Tuesday!!!!
ca
PS She aint no trailer queen!!
Quick Reply: Quadracer threads doing well!
