2009 Suzuki Z400 Nerf Bar Build
Old 11-05-2010, 02:59 PM
WelderShane's Avatar
Default 2009 Suzuki Z400 Nerf Bar Build
Well after looking around at different nerf bars for my 09 suzuki z400 i could'nt find any that i liked and i would rather make my own considering the price of them. I didn't want ones that are real big and stick out even with the tire which most of them are because their ment for racing so you won't get hit by someones rear wheels. But i trail ride more then race so i wanted a smaller pair that protect my feet from sticks/ rocks and such so i figured why not make my own. I wanted steel over aluminum for duraibility. Also they only weigh 2 pounds each. On to the build!
Some left over bent to the perfect angle 7/8''x 16 ga tubing. I had to splice it to make the longer
On to the notching
Time to fit them up and tack
All tacked up
All welded up scratch start tig. Tricky on this thin tubing with no pedal
On to the next post.....
Old 11-05-2010, 03:02 PM
All mounting brackets fitted up and welded. The key is to set the machine hot and keep the heat on the thicker 1/8'' plate and roll the puddle into the 16ga tubing
All done welding that
Tabs i drew up and had them custom cnc plasma cut
Time to tack them on
File Type: jpg
Old 11-05-2010, 03:03 PM
Test fit was done and everything is fine
Tabs all welded up. Same thing with scratch start tig, keep the heat on the thicker edge of the tab and roll the heat onto the tubing while adding filler.
All done
Old 11-05-2010, 03:04 PM
All done Powdered Coated hammered black finish
Webbing all fitted on
Mounted and all done!
Thanks for looking! It was a fun project!
Old 11-07-2010, 10:09 AM
spize909's Avatar
I like those alot! Not too big. and they get the job done.
How is the front attached?
Old 11-07-2010, 02:07 PM
kevin773's Avatar
Thats amazing that you made your own nerf bars! they honestly look better than some of the factory's bars. Way to go
Old 11-07-2010, 06:40 PM
It is attached on the front fender support bracket bolt. I had to replace the 8mm bolt with a longer one due to the one on there is to short and dose'nt bite the threads enough. But its a 8mm bolt so its plently strong enough and i wanted to mount it there instead of off the engine mount bolt because i don't like the way the ones that mount off the engine mount look. You can see in this picture where it bolts in at.
ReconBayou
10-31-2022 05:37 PM
Valder
11-28-2020 07:38 AM
NewGuy2481
10-06-2015 05:54 AM
cboler9
09-24-2015 08:35 PM
XxS0ccerstarxX
09-22-2015 08:07 AM
Quick Reply: 2009 Suzuki Z400 Nerf Bar Build
