what is the difference between a suzuki lt230e and lt 230s
Old 01-03-2011, 05:24 PM
snow racer's Avatar
Default what is the difference between a suzuki lt230e and lt 230s
Old 01-04-2011, 07:13 AM
papa hogg scoot's Avatar
Is one chain drive and one shaft drive? or one is electric start and one recoil only? But i think the differance is chain and shaft drive..But not sure but I can check on this 2 day and let you know.
Old 01-04-2011, 11:22 AM
Trailrider230s's Avatar
the 230s is a kickstart model and the lt230e is an electric start/ pull start back up. also the E model is an automatic and the S model has a clutch.
Old 01-04-2011, 07:48 PM
snow racer's Avatar
Ty vm i wanted to see parts are interchanable. And are the carbs the same.
Old 01-04-2011, 09:40 PM
Scooter86's Avatar
Knows Old ATV Questions!
Most parts are interchangeable. They really are the same machine just different starting and clutch setup. Carbs should be similar also. I would check the microfiche and see if the part numbers are the same.
Valder
11-28-2020 07:38 AM
Steeldon
09-09-2015 09:38 AM
David Diaz
09-08-2015 04:44 PM
jeff mc
Dunes and Dune Machines
09-03-2015 07:47 PM
09-01-2015 11:59 PM
Quick Reply: what is the difference between a suzuki lt230e and lt 230s
