Suzuki Eiger Intermitting fire to sparkplug
I am helping a friend w/a/suzuki eiger 400 4x4 around a 2000 yr. model. When I try to start the engines hits and dies, hit and die. When you pull the spark plug (new plug) and spin the motor over it fires blue for a few seconds and then quits firing, then it will start firing again and quit again. If you keep winding the starter it will eventually start and run good for a while and then it is like you turned the switch off it will die. Please help. Steve931
Eiger first year was 2002. It sounds like the flywheel magnets have come loose. The magnets are know to come loose on the flywheel on the 02-04 models. It is not hard to check. You will need to drain oil and pull off the left side of engine. The sooner the better, before you also break the stator by a loose magnet.
If you search on here for intermittent spark you should find this and maybe a couple other possible problem.
Thank you very much for your time and help w/this. You were correct two of the magnets were loose. I try and help others w/problems when I can and I am glad you do the same. I work on heavy equipment for a living but I like to work on motorcycle,s ,etc. when I have time. If I can help you in any way do not hesitate to email or call. Again Thank,s rwebster@hotmail.com: 931-361-0062
Elkaholic
09-06-2015 02:44 PM
09-01-2015 11:59 PM
