Just picked up a 1990 Quadrunner 250
Old Jan 5, 2011 | 10:25 AM
Ramman1's Avatar
Thumbs up Just picked up a 1990 Quadrunner 250
Hey guys, i just picked up a 1990 (according to VIN) Quadrunner 250 2wd atv for $380. (i think that isnt too bad a deal) The plastics are beat to hell and sewn together with zip ties but it runs great (starts quicker than my Sportsman!). How do i tell what kind of 250 it is? I keep seeing LT250R, LT250S, and LT250T so im not sure what the difference is. Anyone know where i can pick up some plastics and a headlight? Anything to look for with issues on these? Should i change the oil right away? Anyone know where i can find an owners manual? TIA
Attached Thumbnails Just picked up a 1990 Quadrunner 250-1990-quadrunner-250.jpg   Just picked up a 1990 Quadrunner 250-1990-quadrunner-250_2.jpg
Old Jan 11, 2011 | 10:56 PM
TheStigLT250r's Avatar
That's either a lt250s or a lt250f, its not a lt250r because the 250r's are two stroke racing quads. Here's a good website to get plastics for older quads Maier ATV plastic. I would just buy a used headlight from ebay. And it would probably be a good idea to change the oil. You can get a clymers repair manuel at your local motorsports store or off ebay.
I hope that helps, And good luck with your new quad.
Last edited by TheStigLT250r; Jan 11, 2011 at 11:04 PM. Reason: left out information
Old Jan 13, 2011 | 03:49 PM
Ramman1's Avatar
OK thanks - is there any difference between the S or F?? Any idea why the rear tires of this thing bow in so much???
Old Jan 13, 2011 | 06:15 PM
I don't know the difference, but the positive camber should go away once you sit on it.
Old Jan 14, 2011 | 07:56 AM
diamonbird's Avatar
The reason the camber is so bad on the rear tires is the rear shocks are turned all the way to their highest setting.....look at the rear shocks and see.....maybe the person that had that ATV was a little on the heavy side. All you need to do is adjust the spring bottom cams to a lower setting.
Old Jan 14, 2011 | 03:21 PM
Ramman1's Avatar
AH OK this makes sense! Cause it definitely doesnt all go away when i sit on it. Thanks!
Joe454
Nov 20, 2020 01:19 PM
EIF
Apr 20, 2017 07:15 PM
Whitelx1
Oct 2, 2015 10:55 PM
cboler9
Sep 24, 2015 08:35 PM
mywifesquad
8
Sep 21, 2015 08:20 AM
