a couple lt80 questions
when it comes to all the clutch mods on an lt80 what ones need to be done with what stages of engine mods? are there any places to buy some of these clutch parts such as the rollers without going to the dealer? stiffer clutch spring? clutch shoes that have already been shaved? anyone have a ball park price on what porting and head decking cost? i can do all of the labor myself besides the porting and head decking so i was looking for somewhere to just purchase the parts and install them myself. any input you guys can share would help out tremendously. thanks
There are no aftermarket LT80 clutch parts except for the torque spring and that's not messed with till you have a high HP motor.
The customers parts are modified.
thanks i know the shoes get lightened to 180g and remove 2 rollers. depending on pricing i would like to get the porting and head decking done. but if not with just a 51mm piston and 20 mm carb would the above mentioned clutch mods work properly? and can i suzuki bond the head instead of using the head gasket to bump compression?
I'm sure I PM'd you about porting and such.
As to your last question, Yes the 51mm and 20mm carb would work with those clutch mods just the same as 50mm and stock carb. Smoother take off but a tad less top end speed.
I'm hoping you don't think boring and a carb will get you more power and speed.
toonces
10-16-2019 12:11 PM
