Ticking coming from rockers?
Ok so I'm checking the timing just to make sure what to double check for on timing. I had all the lines lined up when I rebuilt. the piston all the way to the top (top dead center) and the timing chain sproket lined up like vault shows, I just did a quick check on the rockers when building, But I think thats were I found the ticking is coming from. So now I have the 2 caps off and wanted to know with the pistion all the way to the top and spark plug out I have found that nether side have any play, But it runs good I just get that ticking at low idle and a back fire one time when iding low. Should that fix the ticking and the back fire i'm getting once I have it gaped right?
Adjust your valves.
Should be done with cold engine.
Back firing through carb indicates intake valve not closing tight ,
or exhaust valve not sealing or opening too early if backfiring out the pipe.
Remove inspection covers turn motor over by hand a few times double check timing marks.
Valves will only have slack in them every other time the piston is at TDC.
