my new home made atv trailer...
Old 05-21-2012, 11:00 AM
beergut's Avatar
ʇsıʇɹɐ ɹǝʌolloɹ
What are you going to use for a ramp surface and, more importantly, did you leave room in the slot to accommodate the extra thickness of the surface material???
using 1"x1" angle iron facing the "V" up- looks like this :
V-V-V-V-V-V-V-V-V-V
they fit into the frame- so no extra height is needed.
Old 05-24-2012, 06:52 PM
Wish i had a fancey tire changer on my trailer
Old 05-25-2012, 12:24 PM
V-V-V-V-V-V-V-V-V-V
Ahhh, I see. I predict bending unless you're planning on welding one angle iron to the next one. Just a guess.
Old 05-25-2012, 01:03 PM
beergut's Avatar
ʇsıʇɹɐ ɹǝʌolloɹ
won't be any bending because the ends are going to be welded to the "T" frame. I got the idea from looking at a heavy equipment trailer ramp.
Kinda hard to explain- you'll get a better picture once it's done. Imagine each end of the "V" welded to a "T" frame. The "T" frame has no flex.
It's actually going to be way overkill for an atv ramp- but I had the steel so whatever.
  #15
Old 10-24-2012, 06:20 PM
Jmb94's Avatar
Very cool... I like.
  #16
Old 10-25-2012, 09:53 AM
BruceDeuce's Avatar
Nice trailer! Wish I had the time to build one.
  #17
Old 10-30-2012, 03:46 PM
Tonyxp's Avatar
You may want to put the "v" s down or they will hold water and mud and speed up corrosion. What is the frame of the ramp made out of, I may be a little leery or it bending a little and then not fitting in its tray. Looks like a nice trailer.
  #18
Old 10-30-2012, 04:23 PM
beergut's Avatar
ʇsıʇɹɐ ɹǝʌolloɹ
the ramp works great- no chance of this ramp bending (unless you drive a fork truck up it) I ended up making the whole thing out of T frame.
slides nicely underneath the floor- I used a heavy duty latch to lock it in place and to prevent it from sliding out- the trailer is a bit heavy- but very solid- you can winch down on any rail or winch point as hard as you want and not worry about something bending or breaking like on the aluminum trailers. I welded a chain to the front with a clasp that locks to the atv hitch- I don't even strap it- I just chain the rear up against the rail, set the parking brake and off I go.
takes only 20 seconds to load or unload-
  #19
Old 03-16-2013, 07:13 AM
beergut's Avatar
ʇsıʇɹɐ ɹǝʌolloɹ
looking at picking up a whole new axle assembly for the trailer today- has electric brakes.
a little on the fence about losing the leaf spring suspension, but I figure it'll be more stable with a heavy load without springs...
  #20
Old 03-16-2013, 09:34 AM
Jaster94's Avatar
you mean to tell me you don't have a local harbor freight store?
it's a right of passage to manhood to go to a harbor freight store!
Quick Reply: my new home made atv trailer...
