yamaha 350 warrior oil leak
Old 01-21-2008, 11:28 PM
tractrnt's Avatar
Default yamaha 350 warrior oil leak
I have a 1987 warrior that is leaking oil behind the output sproket. I took the sproket off it looks like the oil is coming out between the collar and the splined shaft. Do I need to replace the o ring behind the collar. Will the collar come off without splitting the case thanks for any help
Old 01-21-2008, 11:39 PM
beefy46172's Avatar
Loves To Ride!
How bad of a leak is it? If it is just a seep I wouldn't be too concerned about it, but if it is affecting your oil level, that is a different story.
Old 01-22-2008, 01:27 AM
87 warrior's Avatar
even if it is just a seep i would change it anyway because it will only get worse over time. as far as the shaft goes you do have to split the case to remove the shaft i believe. i have an 87 warrior 350 also but i never had that problem.
like i said it will get worse over time so i would change it anyway before it does get worse. but that's just me
Reactant
03-30-2022 02:08 AM
STLyamwar
07-25-2020 04:44 AM
manuelrivera
08-08-2015 04:34 PM
suzukiquadrunner1987
08-06-2015 05:29 PM
Ashley S
07-31-2015 09:46 AM
Quick Reply: yamaha 350 warrior oil leak
