97 Timberwolf ignition switch info, PLEASE!
Ok i got this 97 timberwolf for a hundred buck, the rear diff is trash of course, but other than that not a bad looking atv. It has so much compression that i cant pull start it hard enuff to get it to fire, it takes a big man. The ignition switch is missing, the plug is still there all i need to do is buy a new switch on ebay, my question is, is there anyway to start the bike without the switch there, or is the bike not gonna get any fire? I figured with the switch gona it would be like the atv is turned off. Is there anywya i could jump two of the port in the plug and get it to start, i just want to hear it run. It will turn over fine if i jump the solinoid, but it seems like the kill switch is off , if ya know what i mean. I just a need a little info, you guys are great
The bike is not gonna fire with the key switch off. No one is allowed to tell you how to hot wire a key switch on here so you'll just have to buy a new one off ebay. You can usually get one for about $35. As for the compression, there may be a compression relief lever around the top front of the head. If so flip that up before you pull it and that will make it much easire to pull
