OLD YFM200 diff ratio?
Old 01-14-2013, 08:21 PM
steampunkwilly's Avatar
Default OLD YFM200 diff ratio?
Hi, I have above engine in my Twister hammerhead. it is mounted sideways on the solid swingarm (non IRS) and there is a chain sprocket mounted where the original shaft drive U joint used to be. Chain obviously runs straight to the sprocket on the solid axle.
I need to gear the thing down for off road. I have put 24" mud tyres on the rear (larger than original twister 22"). If Someone knows the original YFM200 diff ratio I will be able to work out the correct sized sprockets to use.
Also How fast could a YFM200 go? I guess I can gear it so it's much lower than a standard bike so then it will conquer the hills even better.
Thanks for any help.
Old 02-20-2013, 02:41 PM
bvolks's Avatar
From my 1985 YFM200 Manual:
Primary reduction ratio : 73/22 (3.318)
Secondary reduction ratio: 19/18x46/11= 4.414
Gear ratio:
1st 3.181
2nd 2.066
3rd 1.428
4th 1.040
5th 0.821
Reverse 3.181
Old 02-20-2013, 06:46 PM
Thanks man, I actually just recently got this info from a local Yamaha dealer which really surprised me. As you say the diff is 4.414:1
I now have the fitters at my work rebuilding my axle for me and I've got a drive sprocket that's a pretty close match for the right ratio. hopefully I'll be mobile soon and actually get to use this beast. It's summer in New Zealand and it's a long dry one for us this year.
I'm also going to try using a car muffler on it to quieten it down a bit so I can take the kids out for a spin. Thanks again.
Alex G.
09-11-2017 11:38 PM
Honski250r
09-26-2015 09:40 PM
rockinkgin
09-25-2015 01:52 PM
John Reed
09-09-2015 03:46 AM
Findlay Tulloch
08-25-2015 05:00 PM
Quick Reply: OLD YFM200 diff ratio?
