2007 yamaha 450yfz
If you hammer to throttle while riding or just sitting at an idle? Does it do it when it's at running temp?
The slight bog is common with YFZ's. It's fixed a bit with a GYTR needle. There's also a "Zip tie" mod you can look into.
Well, as for the problem during idle, it's not a problem i would even worry about. Your just dumping a ton of fuel to an engine running at a low RPM. It just can't burn it fast enough.
Well, that's relative to your experience. I had an issue once with a froze up screw but, other than that it wasn't hard for me. Toughest part was getting the carb out. The link below will give you an idea of what's involved.
CRF's Only - How to change the carb needle and jetting on Honda CRF450X, CRF450R, CRF250R, CRF250X
braap123
09-07-2015 12:58 PM
braap123
09-07-2015 10:57 AM
