2001 bruin 250 carb
Old 04-25-2015, 06:00 PM
4bratsdad's Avatar
Default 2001 bruin 250 carb
hey guys i just picked up a bruin 250 2001 it has carb issues the guy i got it from said he had it apart twice and cleaned it all the jets soaked it but it still cuts out when you give it gas it seems to flood out pretty easy to the point gas come carb itll run but you have to feather the throttle, would like to just replace the carb where is best place to get one are the 70 dollar ebay carbs any good?
Old 04-25-2015, 08:32 PM
Why not just install a carb kit and solve the over flow problem.Usually a worn needle and seat along with possibly the float arm needing adjustment. Shouldn't have to go into a carb more than one.Cleaning doesn't always work. Here's a kit for a later model ,but they probably didn't change much. Plus cheaper than buying piece by piece from the dealer. The 68 bucks carbs are aftermarket ones,may do okay,but possible you'd still have to check/replace the jets if they didn't match yours. http://www.ebay.com/itm/Yamaha-250-Bruin-Carburetor-Carb-Rebuild-Kit-YFM250-2005-2006-/121631076388?hash=item1c51c6f024&vxp=mtr
Old 04-26-2015, 02:57 PM
4bratsdad's Avatar
I don't have any experience w carbs really guy said he cleaned it that didn't work then orders that kit to rebuild it and still did the same , I know when you are trying to start it it takes awhile,and gas comes out of overflow , which made me think it was float out of adjustment or bad float needle ? Isn't it suppose to stop flow of fuel before it runs out of overflow ?
Old 04-26-2015, 03:32 PM
If it has a rebuild kit in it,sounds like he didn't set the float level correctly.The float arm shuts off the fuel supply before it hits the over flow tube inside the carb bowl. RARE occasions the over flow tube can split and can leak regardless of float setting. One way to tell is to remove the bowl,fill with gas and see if it leaks. Found a bunch of these on old Honda carbs mainly.
Old 05-21-2015, 09:04 PM
4bratsdad's Avatar
Well i went ahead and ordered the rebuild kit, and that carb was not recently rebuilt , also found the intake boot was not on all the way causing it to suck air it seems to run pretty good now and idles great, i changed the oil and now it has a ticking sound that it didnt before, i did overfill it a bit & havnt had chance to drain it down,dont know if that could cause it? I watched a youtube video guy changing oil on a beartracker he said they took3.2 quarts of oil so after 1 3/4 i decide to check and it looked like its half or so over does anyone know what they are suppose to take?
Old 05-23-2015, 09:26 AM
cadillacdude1975's Avatar
most of the yamaha 250 engines hold 2 quarts from what i have seen.
Ean
12-19-2022 08:48 AM
Cole Hadden
08-24-2020 11:11 PM
GregM
03-06-2018 06:53 AM
maxjung
07-14-2015 03:10 AM
Robbbb55
CAN-AM (BRP) Ask an Expert!
07-08-2015 02:16 PM
Quick Reply: 2001 bruin 250 carb
