2005 SUZUKI TWINPEAKS 700 LT-V700F
Suzuki proudly introduces the 2005 TWINPEAKS 700. The addition of this new 4×4 big-bore machine to the QuadRunner line marks Suzuki’s first foray into V-twin ATVs. And make no mistake; this one is ready to tackle the roughest terrain around. A powerful 697cc engine, a sturdy frame, durable suspension and a host of other features make the ’04 LT-V700F the ultimate V-twin 4×4 available. The Suzuki LT-V700F is powered by a 697cc four-stroke, SOHC, four-valve-per-cylinder, liquid-cooled 90-degree V-twin. Feeding the torque-laden motor is a pair of Keihin 32mm carburetors with bore and stroke measuring 82.0 mm x 66.0 mm. V-twin torque is transferred through a dual-range CVT-type transmission with reverse and both two- and four-wheel-drive systems. A limited-slip front differential allows for easy turning yet allows the rider complete control in deep mud or on steep uphill trails. An electronically controlled engine braking system assists during descents.
A double-cradle tubular-steel frame was designed for maximum strength and minimum weight. MacPherson struts up front and an aluminum swingarm with a preload-adjustable rear shock provide a smooth ride over any kind of terrain. Front and rear wheel travel measures 6.7 inches. Dual hydraulic discs and dual calipers slow things up front, while a sealed, oil-bathed disc set secure the rear. A digital instrument panel provides all the information a rider could need: speedometer, odometer, dual tripmeters, clock, hour meter and fuel gauge. Also included are indicator lights that denote 2×4 or 4×4 selection, neutral, reverse, low fuel warning and low oil warning.
Completing the machine are stylish and aggressive body panels designed with optimum rider mobility. Front grille, cargo racks at either end and a generous 4.5-gallon fuel tank come stock. Additionally, a pair of 45-watt halogen headlamps lights the way when the sun goes down. The 2004 Suzuki TWINPEAKS 700 – powerful V-twin performance in an exciting and versatile 4×4 QuadRunner package.
- N/A
- Engine: *Four-stroke, liquid-cooled,SOHC, 90 degree V-twin
- Displacement:
- Bore x stroke: *82.0 mm x 66.0 mm
- Compression ratio:
- Carburetion:
- Ignition:
- Transmission:
- Final drive:
- Frame:
- Suspension front / wheel travel:
- Suspension rear / wheel travel:
- Front tire:
- Rear tire:
- Front brakes: *Dual Hydraulic Disc
- Rear brakes: *Sealed oil bathed multi-disc
- Overall length:
- Overall width:
- Wheelbase: *50.8 inches (1290 mm)
- Ground clearance:
- Seat height:
- Lighting:
- Rack capacity, front / rear:
- Towing capacity:
- Fuel capacity:
- Dry weight: *602 lbs. (273 kg)
- Instruments:
- Color choices:
- MSRP: $ 7,099.00
2005 SUZUKI LIMITED EDITION VINSON 4X4 AUTOMATIC
The 2005 Vinson 4X4 automatic is back with an aggressive new look, powerful engine, and all the features you’ve come to expect from Suzuki QuadRunner ATV’s. Introducing the all new 2005 Limited Edition Vinson 4×4 Automatic featuring limited edition black bodywork, silver-colored high capacity racks and trick machine-polished aluminum wheels. The Vinson QuadRunner utilizes a durable 493cc four stroke, liquid-cooled, single-cylinder, SOHC, 4-valve engine with a gear-driven balancer shaft for reduced vibration and is designed for high torque output and quick acceleration. Power is transferred through a fully automatic QuadMatic V-belt transmission with continuously variable gear ratio, centrifugal automatic clutch and a 2-speed sub-transmission with a reverse gear and an advanced engine braking system to reduce downhill speeds. Choose from 2WD or 4WD with the convenient handlebar-mounted electric push button system. The Vinson also comes equipped with a torque-sensing limited-slip front differential for smooth efficient power to both front wheels while in 4WD mode. In-gear starting allows for quick and easy re-starts regardless of transmission setting, while a compact digital instrument display provides all the necessary information for the rider including speedometer, odometer, twin – tripmeters, clock and gear position. The strong and lightweight Vinson frame features a rugged large diameter, thin-walled tubing for maximum strength and minimal weight, double A-arm suspension with 7.1 inches of wheel travel and five position preload adjustable shock absorbers for a comfortable ride and maximum ground clearance (9.8 in.). A swingarm style rear suspension with a single preload adjustable shock absorber is used at the rear with 7.9 inches of travel accompanied by lightweight cast aluminum wheels at all four corners. Large 190mm disc brakes are mounted at the front, while a single 216 mm disc brakes slows things down at the rear. Lightweight skid plate and bumper guards are also mounted to provide maximum protection with minimal resistance over rocks and other obstacles. High capacity racks are included on both front and rear of the ATV for anything you may need to carry.
Other features include bright fender-mounted multi-reflector headlights, large combination taillight/brakelight, and an additional 40W handlebar-mounted headlight. A large T-shaped seat provides comfort and support, while a 325 watt charging system, and a 12V/120W electrical outlet mounted to the front fender with standard automotive style outlets allow for a wide range of electrical accessories to be used.
The ’04 Vinson QuadRunner, Suzuki’s 500cc sport-utility QuadRunner complete with aggressive styling, plus all the features, performance, and versatility that set it ahead of the competition in every way.
- Engine: Four-stroke, single-cylinder Liquid cooled.
- Displacement:
- Bore x stroke:
- Carburetion:
- Ignition:
- Transmission:Variable-speed, belt drive
- Final drive:Automatic Clutch, reverse, High/low range, 2WD/4WD
- Frame:
- Front tire:
- Rear tire:
- Front brakes:
- Rear brakes:
- Overall length: 2095 mm (82.5 in.)
- Overall width: 1170 mm (46.1 in.)
- Wheelbase: 50.0 inches (1270 mm)
- Ground clearance:
- Seat height:
- Lighting:
- Towing capacity:
- Fuel capacity:
- Dry weight: 604 lbs. (274 kg)
- Instruments:
- Color choices:
- MSRP: ,999.00
