2007 Kawasaki KFX 50
Unbeatable features and functionality for younger riders
® The KFX 50 is a best in class ATV perfect for beginning riders age 6 years and older. The KFX50 combines an environmentally friendly 4-stroke air-cooled engine with solid handling, especially important for young riders. A wide 35-inch stance makes the KFX50 stable in turns, while full floorboards provide extra comfort for the rider.
Though it is a compact entry level ATV, features like electric starting, singleshock swingarm rear suspension, A-arm front suspension, dual front drum and single rear disc brakes, mean the KFX50 offers similar styling and features to the larger KFX models.
An adjustable throttle stop, CVT transmission speed limiter and lanyard safety switch allow the rider’s confidence and skill levels to increase while parental control is maintained. Once the rider is confident enough to operate the KFX50 on their own, parents can still maintain control over its operation, thanks to the keyed ignition which helps to prevent unauthorized use.
Authentic Kawasaki Accessories are available through Kawasaki dealers or they can be purchased on the Internet at www.kawasaki.com.
As with all off-highway vehicle recreation, Kawasaki encourages ATV riders to ride responsibly and to respect the environment. Kawasaki will pay first-time buyers of a new Kawasaki ATV 0 for completing an ATV rider safety course conducted by the ATV Safety Institute (ASI). Interested consumers can call ASI toll-free at 800-887-2887.
Kawasaki Motors Corp., U.S.A. (KMC) markets and distributes Kawasakimotorcycles, ATVs, personal watercraft and utility vehicles through a network of more than 1,500 independent retailers, with an additional 7,700 retailers specializing in powerproducts and general purpose engines. KMC and its affiliates employ nearly 2,400 people in the United States, with 400 of them located at the Irvine, California headquarters.
™ Kawasaki’s tagline, “Let the good times roll. ”, is recognized worldwide and the brand has become synonymous with powerful, stylish motorcycles for over four decades. Information about Kawasaki’s complete line of recreational products and Kawasaki affiliates can be found on the Internet at www.kawasaki.com.
- Reliable 49cc air-cooled overhead-cam engine Produces user-friendly power that can be managed by entry-level riders
- Continuously variable automatic transmission
- Electric push-button starting with kick-start backup
- Electrically-operated fuel enrichener automatically opens fuel passage during cranking for easy starting
- Two front drum brakes and a rear disc brake slow things down in a hurry
- All three brakes are activated by the handlebar-mounted brake lever to simplify operation
- Centrifugal clutch on the transmission allows engine braking under certain conditions for added slowing power
- Wide stance for stable handling
- Aggressive sport ATV design similar to larger KFX models
- Steel chassis for durability
- A-arm front suspension
- Swingarm rear suspension
- Chain drive
- 5.3″ ground clearance
- Full floorboards
- Screw-type throttle limiter and collar in the CVT allow parents to set speed and power limits to suit their youngster’s skill and experience
- Ignition-cutoff tether allows an adult to immediately stop engine operation by pulling the tether line.
- Keyed ignition switch prevents starting without a key
- C.A.R.B. certified with USFS-approved spark arrestor
- Engine: Air-cooled, four-stroke, single cylinder
- Displacement:49.5cc
- Bore x stroke:39.0 x 41.4mm
- Compression ratio:10.0:1
- Carburetion:Keihin PTE 16
- Ignition:Solid state CDI
- Transmission:Continuously Variable Automatic
- Final drive:Chain
- Frame:Double cradle, steel
- Suspension front / wheel travel:Single A-arm with twin shock absorbers / 2.8 in.
- Suspension rear / wheel travel:Swingarm with single shock absorber / 2.9 in.
- Front tire:AT16x8-7 tubeless
- Rear tire:AT16x8-7 tubeless
- Front brakes / rear brake:Dual mechanical drums / Hydraulic disc
- Overall length:55.1 in.
- Overall width:34.7 in.
- Wheelbase:38.0 in.
- Ground clearance:Center of chassis – 5.3 in.
- Seat height:
- Lighting:
- Rack capacity, front / rear:
- Towing capacity:
- Fuel capacity:1.5 gal.
- Dry weight:232 lbs.
- Instruments:
- Color choices:Lime Green, White
- MSRP:TBD
