2007 Kawasaki KFX 90
Stable and confidence inspiring with big bike flair
The KFX®90 is the perfect choice for riders 12 years and older. This ATV offers great mid-range engine performance with big-bike flair in its styling. Power comes from an easy to use and environmentally friendly 4-stroke air-cooled powerplant. With its sport ATV design, wide stance, larger tires, and full floorboards, the KFX90 offers handling traits that are stable and confidence-inspiring.
Parents are sure to appreciate the added control offered by the KFX90’s keyed ignition switch which prevents use without the proper key. Once they hand over that key, parents can maintain control over the KFX90’s use via the throttle limiting screw, which allows maximum power to be limited before a young rider uses the ATV.
Authentic Kawasaki Accessories are available through Kawasaki dealers or they can be purchased on the Internet at www.kawasaki.com.
As with all off-highway vehicle recreation, Kawasaki encourages ATV riders to ride responsibly and to respect the environment. Kawasaki will pay first-time buyers of a new Kawasaki ATV 0 for completing an ATV rider safety course conducted by the ATV Safety Institute (ASI). Interested consumers can call ASI toll-free at 800-887-2887.
Kawasaki Motors Corp., U.S.A. (KMC) markets and distributes Kawasaki motorcycles, ATVs, personal watercraft and utility vehicles through a network of more than 1,500 independent retailers, with an additional 7,700 retailers specializing in power products and general purpose engines. KMC and its affiliates employ nearly 2,400 people in the United States, with 400 of them located at the Irvine, California headquarters.
™ Kawasaki’s tagline, “Let the good times roll. ”, is recognized worldwide and the brand has become synonymous with powerful, stylish motorcycles for over four decades. Information about Kawasaki’s complete line of recreational products and Kawasaki affiliates can be found on the Internet at www.kawasaki.com.
- Reliable 89cc air-cooled overhead-cam engine produces user-friendly power that’s easily managed by entry-level riders
- Continuously variable automatic transmission (CVT)
- Electric push-button starting with kick-start backup
- Electrically-operated fuel enrichener automatically opens fuel passage during cranking for easy starting
- Wide stance for stable handling
- Aggressive sport ATV design similar to larger KFX models
- Steel chassis for durability
- Two front drum brakes and a rear disc brake for excellent stopping power
- Centrifugal clutch on the transmission allows engine braking under certain conditions for added slowing power
- A-arm front suspension
- Swingarm rear suspension
- Chain drive
- 5.9″ ground clearance
- Maxxis tires – 18 X 7-8 front, 18 X 9-8 rear
- Full floorboards
- Throttle-limiting screw allows parents to limit throttle opening to help new riders gain experience at slower speeds
- Keyed ignition switch prevents starting without a key
- C.A.R.B. Certified with USFS-Approved Spark Arrestor
2007
- Engine:Air-cooled, four-stroke, single cylinder
- Displacement:89cc
- Bore x stroke:47.0 x 51.8mm
- Compression ratio:10.8:1
- Carburetion:Mikuni PTE 16
- Ignition:Solid state CDI
- Transmission:Continuously Variable Automatic
- Final drive:Chain
- Frame:Double cradle, steel
- Suspension front / wheel travel:Single A-arm with twin shock absorbers / 2.8 in.
- Suspension rear / wheel travel:Swingarm with single shock absorber / 2.9 in.
- Front tire:AT18x7-8tubeless
- Rear tire:AT18x9-8 tubeless
- Front brakes / rear brake:Dual mechanical drums / Hydraulic disc
- Overall length:56.1 in.
- Overall width:35.6 in.
- Wheelbase:38.0 in.
- Ground clearance:Center of chassis – 5.9 in.
- Seat height:
- Lighting:
- Rack capacity, front / rear:
- Towing capacity:
- Fuel capacity:1.5 gal.
- Dry weight:254 lbs.
- Instruments:
- Color choices:Lime Green, White
- MSRP:TBD
