2008 Yamaha Grizzly 700 FI Automatic 4×4 EPS Ducks Unlimited Edition
The Yamaha Grizzly 700 FI Auto 4×4 Ducks Unlimited Edition will have every Duck hunter heading for the nearest Yamaha dealer. This is the best Utility 4×4 ATV Yamaha has come out with.
It is the most Powerful Grizzly ever; the 686cc, liquid-cooled, four-stroke engine has the best power-to-weight ratio of any utility model in the industry. Electronic fuel injection makes cold starts, at any temperature or altitude, a no problem situation. A push button start and a five-position shift lever on the Ultramatic transmission make this the easiest utility ATV to drive.
Exclusive to this Grizzly is a three position On-Command In/Out 4WD feature; it lets the driver switch between 2WD, Limited Slip 4WD or fully locked differentials – all with the push of a button. Another exclusive feature is the electronic power steering system, which is great on long excursions.
The front and rear both have independent double wishbone suspension. 7.1 inches of travel is in the front while the rear has 9.5 inches of travel. There are 5-way preloaded shocks on the front and rear for a controlled ride on any trail conditions. With the independent suspension the Grizzly has a high ground clearance of 11.8 inches. Large Dunlop tires – front AT25x 8-12 and AT25x 10-12 rear – have lightweight aluminum wheels that give a luxurious ride on the trail.
This is the ultimate outfitter’s ATV; front cargo racks can hold 100 pounds and 187 pounds on the rear rack. Under the seat are a 5.3-gallon fuel tank and a 4.8-liter waterproof storage compartment. Heading back after the sun has long set isn’t a problem with the dual 35W Halogen multireflector headlights. The multi function display panel has a speedometer, odometer, dual tripmeters, hourmeter, 4WD status, transmission position, clock and fuel gauge. Overall, this has to be the trickest utility ATV that Yamaha has ever built.
Features
- Compact engine design features a 35-degree cylinder angle for ground clearance and lower seat height for quick steering and maneuverability.
- Gear-driven crankshaft balancer shaft and new-design rubber-damper engine mounts reduce vibration.
- Stainless steel exhaust system features aluminum heat shields and a screen-type spark arrestor for great power with minimum noise output.
- High-capacity aluminum radiator with fan-assist delivers maximum cooling efficiency and is positioned high in the frame for optimal protection.
- Automatic cam chain tensioner reduces engine maintenance and helps extend engine life.
- Override button allows engine to make maximum rpm in full Diff Lock mode.
- Sealed drive case keeps out water and debris to help prevent belt from slipping.
- Four-wheel hydraulic disc brakes serve up consistent, long lasting braking power under all sorts of nasty conditions.
- Rugged injection-molded front bumper and CV joint guards protect against rock and debris damage.
Specifications
- Model: YFM7FGPDUX
- Engine Type: 686cc, 4-stroke, liquid-cooled single; SOHC, 4 valves
- Bore x Stroke: 102.0 x 84.0mm
- Compression Ratio: 9.2:1
- Carburetion: Yamaha Fuel Injection (YFI); 44mm 32-bit ECU
- Ignition: 32-bit ECU
- Starting System: Electric
- Transmission: Yamaha Ultramatic® V-belt with all-wheel engine braking/H, L, N, R, P
- Drive Train: Yamaha On-Command® pushbutton; 3-way locking differential; 2WD, 4WD, locked 4WD; shaft drive
- Suspension/Front: Independent double wishbone;5-way preload adjustment, 7.1-in travel
- Suspension/Rear: Independent double wishbone;5-way preload adjustment, 9.5-in travel
- Brakes/Front: Dual hydraulic disc
- Brakes/Rear: Dual hydraulic disc
- Tire/Front: AT25 x 8-12; aluminum wheels
- Tire/Rear: AT25 x 10-12; aluminum wheels
- Length: 81.3 inches
- Width: 46.5 inches
- Height: 48.8 inches
- Seat Height: 35.6 inches
- Wheelbase: 49.2 inches
- Turning Radius: 126 inches
- Ground Clearance: 11.8 inches
- Fuel Capacity: 5.3 gallons
- Dry Weight: 600 pounds
- Rack Capacity: 99 lbs Front, 187 lbs Rear
- Towing Capacity: 1,212 lbs
- Instrumentation: Digital LCD multifunction display: speedometer, odometer, dual tripmeter, hourmeter, clock, fuel gauge, gear position, EPS and EFI function
- Lighting: Dual 35W Halogen multireflector headlights & 21W/5W brakelight
- Color: Advantage Max-4 HD® Camouflage
- MSRP: ,699
