Ask the Editors: LT80 Part Identification Help
Dear ATVC: Reagrding the clutch assembly on a Suzuki LT80 , there is a little metal piece at the end of the crank shaft that spins something which drives an oil pump on top of the clutch cover so the metal piece is split in half. but I can’t find the part cause I don’t know whats it’s called and I can’t find a picture of the assembly online. Anyone know what its called? Joseph Gurganus
Here is the schematic of the oil pump assembly itself:
From the sounds of it, perhaps you are describing either of the pump gears (parts # 10 and/or 13?). If so #10 refers to part # 1632003A02, GEAR,OIL PUMP D, USD $39.14 and # 13 is part # 1633111B00, GEAR, OILPUMP DR, USD $22.19.
If what you are describing can’t be found on this schematic, then it is not considered a part of the oil pump assembly. It could be part of the clutch cover or crankshaft so we’ll include those schematics as well in the hope of you locating what you need:
Crankcase (left cover) diagram.
