Check out the 2023 ARGO FRONTIER 700 8X8
It’s tough to argue with a machine that’s rated to carry six humans on land and four through water. The Frontier 700 6×6 returns for the 2023 model year featuring its reliable Briggs and Stratton 23hp EFI air-cooled engine. This model comes standard with factory-installed front and rear bearing extensions for added axle strength and easy snowplow mounting, a full-length skid plate, and a fuel-injected engine. The ITC (Instant Torque Clutch) that responds quicker than previous model years and increases torque to the tires for better overall performance with or without tracks installed. A 8.5-gallon fuel tank with digital gauge increases range, full-motion chain tensioners reduce chain stretch, and led brake taillights. The engine is a Briggs and Stratton Vanguard 23hp EFI air-cooled engine mated to the Generation II Classic transmission in a standard 2.6 gear ratio. Argo APS steering reduces driver fatigue and is much smoother to drive than older Argo models with left-hand drive and a finger pull throttle.
Argo designed XT115 24×10-8 (610 mm) 4 ply mud and swim tires mounted on offset steel 8″ rims combine to give this machine great traction and best in class payload all while providing a water speed of 3.0 mph. The Frontier 700 8×8 is the best bang for your hard-earned money for those looking for a duck hunting, ice fishing, or recreational unit who are on a budget but don’t want to sacrifice cold-weather performance, cargo capacity, or capability. Available in black, orange, or tundra green.
This Frontier 700 8×8 is powered by a 4 stroke OHV V-Twin air-cooled 627cc, 23 hp (17 kW) Briggs and Stratton engine with electronic fuel injection. It has a load capacity of up to 840 lb. / 381 kg on land or 740 lb. / 335 kg on water, can transport 6 passengers on land, and up to 4 persons on water, and features a towing capacity of 1,200 lb. / 544 kg. Available in tracked or non-tracked configurations.
INSTANT TORQUE CLUTCH (ITC)
New for 2022, Argo developed the Instant Torque Drive System (ITDS), which improves low-end torque and increases acceleration. The new Instant Torque Clutch (ITC) is designed to provide the optimal gear ratio in all terrains and conditions or whether you are running tracks.
Torque increases 28% compared to our previous optional HT (3.3 or 8.1) transmission ratios and acceleration increases by 25% compared to our previous clutching when tested on the standard ratio Admiral or Classic transmissions.
APS STEERING
The APS (Argo Progressive Steering) is an innovation in the area of braking force applied to the transmission steering differential. This new steering system implements a dual-rate progressive spring allowing the vehicle to turn in one continuous motion making the vehicle easier and more comfortable to drive.
FEATURES
• Argo Generation II Planetary differential transmission with High/Low Forward, Neutral, and Reverse.
• Optional low 3.3 gear ratio for increased torque.
Briggs and Stratton Vanguard 23hp Air-Cooled EFI Engine provides:
• Increased fuel efficiency
• Reliable cold-weather starting
• Improved high elevation performance
• Onboard diagnostics
• Electronic ignition
• Three-year limited engine warranty
• Large rear cargo capacity
• Long wheelbase for increased ride comfort over rough terrain
• Large 72mm triple-sealed outer axle bearings
• Standard front and optional rear bearing extensions
• 8-wheel drive with a low center of gravity for extra stability
• 24×10-8 (610 mm) ARGO tires with proprietary tread design
• Standard full-length skid plate for lower body protection
• Standard front and rear bearing extensions
• Standard bilge pump
• Digital Gauge Cluster
STANDARD WARRANTY
Engine: 3 Year Briggs and Stratton Limited Warranty
Chassis: 1 Year Argo Limited Warranty
Transmission: 1 Year Argo Limited Warranty
STANDARD EQUIPMENT
• Briggs 23hp EFI Air Cooled Gas Engine
• 8 inch Steel Offset Rims on 24×10-8 Argo Tires
• Front and Rear Bearing Extensions
• Full-Length Skid Plate
• Bilge Pump Kit
• Generation II Transmission with Standard 2.6 Ratio
MSRP
Starts At $19,699.00
MORE INFO
Click Here
