HJC Releases All New CL-X7 Helmet
The all-new CL-X7 packs more advanced technology and value into its shell than any other helmet in its class. The new shell sculpture is not only targets cosmetic appeal, but the clean angular lines also add structural integrity. For example, think of how corrugation adds strength to a cardboard box, without the corrugated design the box will be very fragile and flimsy. This particular design is especially helpful with the chin bar’s strength. In addition to the shell design, the CL-X7 is neck brace compatible and has a collarbone friendly profile. They have also added a much larger eye port for maximum visibility making it fit virtually any goggle size.
When designing the CL-X7, HJC didn’t just want it to look good, but wanted it to function well. For starters, they integrated an ACS ventilation system that includes an aggressively designed EPS, 14 front air intake; 4 in the mouth piece, 6 forehead vents, and 4 more underneath the visor. The front intake was designed to create a ram force air induction system, for maximum air flow. On top of the 14 intake vents, they have added 4 large rear exhaust ports. With the help of their aggressively designed EPS, the rear exhausts pushes out the hot & humid air up and out off your helmet.
In addition to the ACS ventilation system, they have added what they call their Super Cool Interior. The interior is removable, washable, moisture wicking, and anti-bacterial treated. With the Super Cool Interior, you will get a cooler, drier, and more comfortable ride, even at lower speeds. The cheek pads are ergonomically contoured to cradle jaws and cheeks. This design will result in a more secure fit, that doesn’t squeeze or pinch the softer tissue of the cheeks. Lastly, they have added printed graphics on the interior and a subtle injection molded graphic, detail on the eye port gasket and bottom edge.
For more info go to www.hjchelmets.com or call 562-407-2186.
