Lockstraps Universal Locking Tiedowns Released
We here at ATV Connection are always on the lookout for products that reduce the risk of theft of our beloved ATVs and UTVs. To that end we’re pleased to pass on the news that Lockstraps has recently released several new items to their impressive universal product line up including the third generation of their locking tie-down and several options of their Lockstraps Universal Single Combination Locking Carabineers.
The third generation Lockstraps G3 feature tougher locking carabiners, (#64 Hardened Steel; Heat treated) a stronger sliding clasp and come in a sealed clamshell package that can be set on a shelf or hung from a wall hook.
Lockstraps G3 are built with a stainless steel cable sewn between double nylon straps. Tough galvanized steel rivets keep dual combination carabineer locks in place at both ends of the Lockstraps. The Lockstraps also incorporate a soft tie-extension to eliminate scratching.
Users can change the combination of the locks with each use and can set their own personal combinations on either carabiner.
The new G3 straps are 8.5-feet long, 1.5-inches wide, 1/4-inch thick, and weigh 2.3 lbs. each. They come backed with a 100% Satisfaction Guarantee and a 365-day parts and labor warranty. Each Lockstrap is sold individually with a retail price of $44.95.
Finally their universal single combination locking carabineer with a two foot cable/strap perfect for a jacket/helmet lock or many other uses.
Made of #64 hardened steel, heat treated, this carabineer is made TUFF! The strap has two nylon straps sewn together with a 3mm stainless steel cable in the center. Galvanized steel “beefy” rivets hold the loops on the ends together so a thief would need tools if they wanted to try to break it.
With a retail price of only $24.95, this lock is great to throw in your pocket, bag, or hang it from your belt loop. Don’t let someone take your helmet and leave you stranded.
The carabineer is 6.5 inches tall and 3 inches wide so it is perfect for many uses!! It is easy to set the three digit combination and you can change the combo any time; All you need is a ball point pen!! 100% Satisfaction Guaranteed Peace of Mind!
Finally their universal single combination locking carabineer with a twenty four foot cable/strap.
Perfect for Power sports, Marine, Tools, Equestrian, Medical, and much more!! Use it like a cable/chain lock, securing all of your stuff at the same time…Light weight, only 3lbs!
Made of #64 hardened steel, heat treated, this carabineer is made TUFF! The strap has two nylon straps sewn together with a 3mm stainless steel cable in the center. Galvanized steel, “beefy” rivets hold the loops on the ends together so a thief would need tools if they wanted to try to break it.
Lock your stuff to keep 90% of theft away! The carabineer is 6.5 inches tall and 3 inches wide so it is perfect for many uses! It is easy to set the three digit combination and you can change the combination any time; All you need is a ball point pen!
More information can be found at the company’s official site by clicking here.
