Meet the 2020 Arctic Cat Side-by-Sides
A few less on the line for 2020.
After being acquired by Textron, the beloved Arctic Cat line went through some rebranding only to return to the Arctic Cat banner once more. The sad news is for 2020 the the SxS arrives a few machines shy. The Wildcat X, Wildcat Sport and Wildcat Trail have all been nixed this year. But let’s not dwell on the past, but rather take a look at what AC is bringing to the table for 2020.
Wildcat XX
A side-by-side ready to take on dirt, dunes, mud and rocks with 130HP and suspension technology rooted in off-road racing.
Premium FOX 2.5 PODIUM QS3 Shocks with Bottom-Out Control
998cc 3-Cylinder Naturally Aspirated EFI Engine with 130 HP
18 Inches of Front and Rear Travel
2WD/4WD with 4WD Lock
14-inch Ground Clearance
HAVOC
Command the job and the joyride with class-leading suspension, heavy-duty towing capacity and relentless power.
100HP EFI Engine
Four-Wheel Double A-Arm Suspension
24 cu-ft of Storage
2000-lb of Towing
600-lb-Capacity Tilt Bed
Best-in-Class 13-inch Ground Clearance
Standard Accessories: Hard Roof, 4500-lb Winch, HD Front Bumper, Steel Wheels with Duro Tires
STAMPEDE
846cc, 80-horsepower inline twin and double-A-arm suspension with 9.5 inches of travel up front and 10.5 in the rear. This machine’s four-wheel-drive system features selectable 2WD/4WD, an automatic-locking front differential and a lockable rear differential.
PROWLER PRO CREW
An additional row of bench seating, so you can bring three more passengers along for the ride.
6-Passenger Bench Seating
Whisper-Quiet 812cc 3 Cylinder EFI Engine
17.95 cu-ft of Storage
2000-lb Towing Capacity
1000-lb Capacity Cargo Box with Tilt
PROWLER PRO
Loaded with a whisper-quiet 50HP engine, tons of storage space and more than 50 custom and easy-to-install accessories.
3-Passenger Bench Seating
PROWLER 500
Space for everything you need, power to haul it and an efficient engine to keep you going strong.
Class-Leading Enclosed Storage
443cc Liquid Cooled Single Cylinder Closed-Loop EFI Engine
Front and Rear Double A-Arm Suspension
1500-lb Towing Capacity
500-lb Rear Cargo Capacity
