Piece of Mind – Pro Armor Skid Plates
The rear swing arm skid plate is made of ¼” thick aluminum. It protects your swing arm along with your lower shock mount, rear brake disc, sprocket and chain. Ever priced a brake disc? They are not cheap! Install this heavy-duty skid plate and never worry about it again! It also has a two-strap slot cut out of the rear of the skid plate, which is handy, when you need to tow a friend back to camp. It allows all the towing weight to be low for maximum traction.
This skid plate bolts over the stock plastic “skid” rails. It seemed like it lowered the ground clearance quite a bit, but in reality, it’s only ¼” lower. It felt like we were dragging more in rutted out trails. What is really happening is the skid plate provides more surface area to drag than the stock plastic skid rails did. Installation was a little tricky, but not hard. For a couple of the bolts, you will need to lay down facing the rear of the ATV to be able to see what you are doing. Then, you will need to rotate the axle/sprocket to insert your hex key through the sprocket into the bolt. It’s a tight fit, but again, it’s easy.
The exhaust shield is designed to add style while keeping the rider from getting burned on the pipe by dissipating heat faster than the stock steel shield. It bolts on in seconds with the existing hardware.
Pro Armor offers high quality protection for a good price.
Next time you are thinking of spending your hard-earned cash on an exhaust pipe to gain a few extra horsepower, think about investing in some products to make it back to camp and at the same time save your investment!
