Suzuki 2018 ATV Lineup
Suzuki unveils its ATV line for 2018.
2018 Suzuki QuadSport Z50
The 2018 Suzuki QuadSport Z50 is designed for adult-supervised riders age 6 and older and includes many features that make learning to ride a safe and fun experience. The QuadSport Z50 features a throttle limiter to control engine output, a tether switch to remotely shut off the ignition, and a keyed main switch that prevents unauthorized use. Adjustable hand controls, an automatic transmission, full floorboards, and a low seat height make sure that beginning riders will enjoy active convenience and control. MSRP $2,049, available in Championship Yellow, in dealers in July 2017.
2018 Suzuki QuadSport Z90
The 2018 Suzuki QuadSport Z90 is for adult-supervised riders age 12 and older. New riders will appreciate convenient features like an automatic transmission and electric starter. An easy-to-set throttle limiter lets adults set the power level appropriately for young riders, and a keyed ignition switch makes sure there are no unauthorized rides. Like the QuadSport Z50, the Z90 is packed with quality, safety and style making it the perfect choice for young ATV riders to learn on. MSRP $2,949, available in Black/Yellow, available in dealers in July 2017.
2018 Suzuki KingQuad 400FSi
The 2018 Suzuki KingQuad 400FSi features a five-speed manual-shift transmission and semi-automatic clutch for riders for favor sportier ATV performance. The fuel injected 376cc engine cranks out an impressive amount of torque and has an incredibly wide powerband for increased performance. Durable manual transmission with semi-automatic clutch lets the rider select how the power is delivered and it’s easy to select 2WD or 4WD via a handlebar-mounted lever. The engine also delivers outstanding fuel efficiency, clean emissions and great performance. The KingQuad 400FSi is available in Flame Red or Terra Green body work with rugged front and rear cargo racks. MSRP $6,499, available in Red or Green, in dealers in September 2017.
2018 Suzuki KingQuad 400ASi
The 2018 Suzuki KingQuad 400ASi has a fully automatic Quadmatic transmission, with two- and four-wheel drive modes to handle rough trail conditions. The air-and-oil cooled fuel-injected 376cc four-stroke; four-valve engine produces efficient power and drivability across the entire powerband. The KingQuad 400ASi is available in Flame Red or Terra Green body work. The KingQuad 400ASi CAMO has True Timber camouflage on the rugged fenders to help riders blend in when they don’t want to be seen. For 2018, the KingQuad 400ASi is also available in a Special Edition finish of Solid Matte Sword Black. MSRP $6,499 for Red or Green, $6,899 for CAMO, and $6,799 for Special Edition, in dealers in September 2017.
2018 Suzuki KingQuad 500AXi
The 2018 Suzuki KingQuad 500AXi’s fuel injected, 493cc, liquid-cooled engine provides exceptional performance throughout the powerband with a strong mid- to high-end punch. The fully automatic Quadmatic transmission incorporates an advanced engine-braking system minimizes free-wheeling with the throttle off and helps control the vehicle during steep descents. Easy, push-button controls let the rider choose between two-wheel drive, four-wheel drive or four-wheel drive with a locked differential. Available in Flame Red or Terra Green, the KingQuad 500AXI is also offered in True Timber camouflage. MSRP $7,399 for Red or Green, and $7,999 for CAMO, in dealers in July 2017.
2018 Suzuki KingQuad 500AXi Power Steering
Riders will really appreciate how the innovative, electronic power steering system reduces turning effort and damps vibration to the rider. Available in Flame Red, Terra Green, or True Timber camouflage the KingQuad 500AXi Power Steering is also available in a Special Edition finish of Solid Matte Sword Black. MSRP $8,299 for Red or Green, and $8,699 for CAMO, in dealers in July 2017.
2018 Suzuki KingQuad 750AXi
The 2018 Suzuki KingQuad 750AXi is designed for high performance on the trail or on the job. Its powerful 722cc, fuel-injected and liquid cooled engine features a twin-spark-plugs for quick starting in cold weather and smooth, strong overall performance. A large under-seat fuel tank keeps seat height low while the plush, T-shaped seat delivers an extended, comfortable riding range. Riders are in full control at all times as the fender-mounted shifter controls the range or reverse selection of the fully-automatic, Quadmatic transmission. Mounted right on the handlebars is a pushbutton 2WD, 4WD or 4WD full-lock drive mode selector and an over-rev button that makes sure riders have the power they need to get the quad out of muddy, sticky situations. The ride is smooth through the fully independent and adjustable suspension that has the cargo or towing capacity. Available in Flame Red or Terra Green, the KingQuad 750AXi is also offered in True Timber camouflage. MSRP $8,599 for Red or Green, and $8,999 for CAMO, in dealers in July 2017.
2018 Suzuki KingQuad 750AXi Power Steering
Because the innovative, electronic power steering effort is so light, this Quad has higher handlebars designed to increase the riders comfort. Available in Flame Red, Terra Green, or True Timber camouflage the KingQuad 750AXi Power Steering is also available in a Special Edition finish of Solid Matte Sword Black. MSRP $9,199 for Red or Green, $9,699 for CAMO, and $9,599 for Special Edition, in dealers in July 2017.
