HOW TO carb adjustment on any Chinese atv. Kazuma, Yamoto, Redcat, Baja, Sunl, etc...
#23
#24
#25
#26
How does the "E-clip", spring, slide and needle jet go together (Keihin 19 mm)? Specifically, how does the E-clip work? When I took it apart, it kinda fell "sprung apart". I know how the needle jet sets in the slide, the throttle cable connects to the slide through the spring. Does the "e-clip" set on top of the needle jet below the spring? I can't find a diagram anywhere (only some exploded views that are not particularly clear).
#27
The needle is inside the carb slide. So when you remove the slide then disconnect the cable there is a retainer clip that holds the needle into the slide. Once you remove the retainer clip the needle will come out. On the needle there are 5-6 slots on the clip. The E- clip will go to the lower slot for colder weather and middle to upper for hot weather. Just make sure when you put the needle back in that you put the retainer clip on the right way or you will not be able to get the cable back into the slide. Also make sure when youinstall the slide back into the carb that it is installed right or when you go to start it the quad will take off because it will be in a full throttle position. The slide can be installed 2 ways. The slot that the cable goes into always goes opposite of the idle screw.
#28
Thanks, I think I got it right but not before experiencing the full throttle thing first hand. I never thought about what happens when you squat next to the ride and start an auto clutch in gear with a throttle stuck wide open. It is funny in retrospect. As I noted in another thread, I looked like a steer roper trying to throw the steer to the ground. The bruises will heal soon!!
