which is idle screw or air screw on carb
Old Jun 7, 2008 | 10:21 AM
08ninja250r's Avatar
Default which is idle screw or air screw on carb
Hi,
I am new to the forum, mostly worked on motorcycles. I did find a post regarding tuning the carb from "too many toys", great post.
I purchased a new chinese 110cc mini quad for my son. However it runs very poorly bogging out at 1\4 to 1\2 throttle.
The is running to rich, i can tell from the smell of unburnt fuel.
Normally, the idle screw has a spring on it but these 2 screws on this carb are flat with springs inside, very strange.
I have a picture of the bike and carb but donot know how to add it to this post, any help is much appreciated.
thanks
Old Jun 7, 2008 | 03:38 PM
outofline's Avatar
To add a photo to this site is easy just click on the "My Page" up towards the top of this forum page and then go to edit. Then to post it here copy the pic's location and paste it in the post with [img][/img] on each side of it! The Idle screw should be the one on the right side of the carb (as mounted to atv). Sounds as if you need to adjust your needle by lowering or raising the clip (not sure which) but if you look through my older posts about my 150's I had to do the same back almost a year ago!
Old Jun 9, 2008 | 08:05 PM
Thanks for the reply and help.
Here is a picture of the carb. I believe the idle screw is the top and the air screw is to the left next to the air filter.
110cc carburator
Old Jun 9, 2008 | 08:38 PM
outofline's Avatar
Ummmmmm, thats a pic of my 150's shifter?
Old Jun 10, 2008 | 02:59 AM
outofline's Avatar
Here it is!
Old Jun 10, 2008 | 03:04 AM
outofline's Avatar
I believe the forward screw (highest one) is the Idle adjust. By screwing it in it simply lifts the carb slider up to allow more air to get by. The rear screw must be the air fuel mixture would be my guess.
Old Jun 10, 2008 | 12:00 PM
Thankyou for the help!
I will change the spark plug to the recommended NGK and try to make some carb adjustments later this weekend.
I have the "too many toys" post, if it is not too much trouble, do you have the link to the post about the 150's?
I will continue to search for it...
ranvette
Jul 12, 2015 06:34 AM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
MNatv89
Jul 7, 2015 11:36 AM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
