please help
Old Sep 11, 2009 | 05:52 AM
dwshaff@sbcglobal.net's Avatar
Lightbulb please help
I have three questions about a sunl sla 109 :
1. can i do away with the remote start stop and install a regular key switch.
2. where can i get manuals for this unit showing wiring diaghrams.
3. also can i install a rope or kick starter
Old Sep 18, 2009 | 10:12 AM
LynnEdwards's Avatar
Electrical Expert
It should already have a key switch, right? But the key switch won't turn off the ATV if the remote module is unplugged. This is because the kill switch wire from the ignition switch is routed to the other kill switches through the remote module. Thus to get the ignition switch to work right you'll have to add a jumper to the remote module connector.
I don't have a wiring diagram of your quad but here is a manual for a similar quad. On the last page is a wiring diagram including a remote module. It should be fairly close.
http://www.adventureimports.co.nz/in...ATV_manual.pdf
