headlights
Old Jan 22, 2010 | 07:43 AM
aaronrkelly's Avatar
Originally Posted by windtrader
Those should work out fine. Might look a bit goofy but if the kids don't moan who gives a rats ***. Enjoy!
I dont think they look that bad....I even found one with a blue tint to match the yellow/blue theme on the LT80.
Old Jan 27, 2010 | 11:47 AM
youngnbald's Avatar
Just finished installing the Navigator Driving lights with H3 35w bulbs. Still need to wire and test yet. I don't think they turned out bad and should be intense with the halogens.
Found the file size is too large and needs to be reduced! ARG~ will upload later or check my albums...might work there.
Old Jan 27, 2010 | 12:04 PM
youngnbald's Avatar
Pictures may work now
Attached Thumbnails headlights-011910_002.jpg   headlights-012710_001.jpg   headlights-012710_002.jpg   headlights-012710_003.jpg
Old Jan 27, 2010 | 12:09 PM
windtrader's Avatar
Looks super! and a bit cold!
Old Jan 27, 2010 | 12:21 PM
  #15
youngnbald's Avatar
with the right clothing, it is perfect out there!!!! Water and ground is frozen again and less mud to deal with. The dirt bike had a good 20-30ft rooster with the mud. 20 minute ride, 2 hours to clean up! I will take the cold for a bit.
Old Jan 27, 2010 | 12:27 PM
  #16
youngnbald's Avatar
This should give you an idea. I need to get the helmet cam on when I do the rooster tails!
Old Jan 27, 2010 | 08:06 PM
  #17
youngnbald's Avatar
WOW, just took the machines for the night riding and this upgrade is HIGHLY recommended!!!! Perfect lighting and the intensity is perfect!!! Very simple to wire up and creativity makes the mounting easy also. Would recommend for anyone using the machines in the dark.
Old Mar 17, 2010 | 06:30 PM
  #18
dgriffin75's Avatar
Default Driving lights on Baja
Hey guys,
I'm new to the forum. I thought you guys would be interested to know that the driving lights that you can get at Wal-mart (for $20) do work great as an upgrade.
I installed a pair on a Baja 90cc that didn't have any lights on it when I got it. The lights are great for night riding.
Old Mar 17, 2010 | 10:28 PM
  #19
Originally Posted by dgriffin75
Hey guys,
That is what Im running on the LT80 in the first post on this page. If your setting this up for the little ones might I suggest a simple red clearance light on the back for a tail light......makes a rear-end collision less likely, Im always worried about someone running over the top of them on these little machines.
Old Sep 11, 2010 | 08:01 PM
  #20
mab9981's Avatar
Default headlights
i installed the fog lights from walmart and it turned on and was great.
but now for some reason none of my lights work. my brake light still works and my electric starter still works, but my lights won't come on.
is there a fuse for the lights?
i found the fuse near the battery, but it's fine.
any of you guys have this issue?
