Need help with a 110 taotao
Old Mar 24, 2010 | 12:44 PM
peak zj's Avatar
Default Need help with a 110 taotao
Ok, my daughters 110 will not stay running and runs irratically when you have it throttled up..
I've completely cleaned the carb..
New plugs(NGK)
drained fuel, just in case
adjusted idle screw
It acts like there is a firing issue...
Any thoughts on this??
Plug turns black fast...
Thanks,
Ted
Old Mar 25, 2010 | 01:39 AM
Blaster Guy's Avatar
Have you done a compression test? I'm fairly new to the 4 stroke side of atv's but sounds like your either running very rich, or you have a bad ring/cylinder seal. If your compression is good, I have heard you can lower the needle in the card to lean it up a bit. Do you have good spark?
Old Jun 4, 2010 | 07:41 PM
spraynkoolkolors's Avatar
make sure choke is opening all the way
hugemoth
Jul 20, 2020 03:28 AM
jeepwheelin02
1) Engine problems..
Jul 18, 2020 06:42 PM
Randy Marsh
3) General Discussions..
21
Nov 10, 2015 01:45 PM
Unzzy66
Jul 11, 2015 10:01 PM
