what goes in this and what is it for
Old Apr 3, 2010 | 09:45 PM
jasonace99's Avatar
Default what goes in this and what is it for
there are two red arrows the top one is a fill plug i need some info on is it oil? and does it need oiled after an oil drain/refill
second arrow is a small cover behind is a bolt is this a clutch adjustment?
Old Apr 6, 2010 | 12:12 AM
LynnEdwards's Avatar
Electrical Expert
I'm not familiar with you engine. I'm wondering if the top side "fill plug" is really an access hole to shine a timing light down onto the timing marks. My 150cc quad has a hole very similar to this. On mine I shined a timing light in there, and yes, I see timing marks with the strobe light.
Old Apr 10, 2010 | 04:25 PM
befarrer's Avatar
They are both to do with timing, the top plug is to shine a timing light into, or to allign the engine up at TDC, and the side cover opens up a hole so you can rotate the engine over with a socket on the flywheel bolt. I have a 200CC GIO quad with a Zongshen motor, it looks identical to yours.
