Coolster 125 ATV electrical problems
Old Jun 20, 2013 | 10:41 AM
kenny logan's Avatar
I bought a 2013 Coolster 125cc for my son for Christmas and was running fine and then one day it wont start, the battery is charged, i turn the key on and then nothing happens, I press the start button with the key in the on position and I have nothing, no click sound, nothing. What could this be?
Old Jun 23, 2013 | 03:12 PM
JoDean Gillum's Avatar
I have an Cruz-in CZ-200XTR ATV I am looking fora wiring guide the last owner really messed it up. If anyone has any suggestions I would be eternally grateful.
Thanks JoDean
Old Aug 1, 2016 | 08:05 AM
chevyboi16's Avatar
I'm trying to figure out why mines don't crank all I hear is clicking
Old Aug 2, 2016 | 02:35 AM
One click when you press the button, faulty starter or solenoid. To check if it is a faulty starter, get a 12v test lamp connect one lead to earth and the other to the wire between solenoid and starter, ignition on, press the start button, if the lamp lights but the starter doesn't turn, you have a faulty starter. If the solenoid clicks once but the lamp doesn't light, faulty solenoid.
If you get a buzz when you press the button, flat battery (or bad connection), or seized engine.
Old Aug 3, 2016 | 06:55 AM
  #15
MPDano's Avatar
You could always jump the solenoid and if the starter turns, replace solenoid. Verify battery voltage. 13.2 is a properly working battery. 2.2 volts per cell.
Old Aug 3, 2016 | 07:20 AM
  #16
chevyboi16's Avatar
Yeah I checked the battery with the mutimeter it read 12.23 but when I turn the key it drop down 9 volts so I order another battery but the starter is shot so I have to order another one next week
Old Aug 3, 2016 | 08:35 AM
  #17
MPDano's Avatar
How do you know the starter is bad? Did you try and hook it up to a car battery?
Old Aug 3, 2016 | 08:38 AM
  #18
chevyboi16's Avatar
Yes indeed I did plus I took cover off and it had rubber pieces in it
Old Aug 4, 2016 | 10:15 AM
  #19
MPDano's Avatar
Ha ha. No bueno.
Old Aug 4, 2016 | 10:17 AM
  #20
chevyboi16's Avatar
My new battery came in didn't try it yet
