Choosing a high speed jet 250cc GIO
Old Jul 29, 2010 | 01:14 PM
aircube's Avatar
Default Choosing a high speed jet 250cc GIO
I am running a 102.5 high speed jet in a 30mm Mikuni Carb on a 250cc GIO badboy quad. When i check the plug after a high speed run it looks fairly white and I am wondering if I should try some larger sizes.
The stock carb had about a 90 or a 95 HS jet. When I bought the upgraded Mikuni carb it came with a 100 HS jet. The largest I had is a 102.5 and thats what worked with the stock carb so thats what i tried.
is there a formula for choosing jets? I read that you multiply the throat by 4.1-4.3.
So, 4.2*30mm= 126 !!!
Is it possible that these companies(like GIO Kazuma, etc) are selling these things with the std "100" jet becasue that's what Mikuni ships out as a default in their carbs?
100-102.5 seems a far cry from 126.
Anyone else jet a 250cc?
Any suggestions?
Old Aug 16, 2010 | 10:27 PM
FURY 250s's Avatar
Hi Bud
new to the forum
your 125-126 is just a guide with saftey in mind, i think your best bet will be 105
i will be putting a mikuni 30mm on mine in a few days and will let you know my findings
I also have contacted oko carbies aswell and i will be trying to put 1 of these in 1 of my atvs aswell, just waiting on oko to get back to me today
Old Aug 16, 2010 | 11:03 PM
aircube's Avatar
The 102.5 seems pretty good right now I have gone on a couple of long rides, one on a 40 deg C humidex day andno overheating.
Interested to hear what the 105 is like.
Old Aug 20, 2010 | 11:03 PM
FURY 250s's Avatar
the 105 will only make your motor run cooler as it flows more fuel therefore little less power
mywifesquad
8
Sep 21, 2015 08:20 AM
Steeldon
Sep 9, 2015 09:38 AM
black_thunder
Sep 6, 2015 04:41 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
JakeXBL
Sep 5, 2015 01:08 PM
