ata 250e toa toa
Old Aug 2, 2010 | 10:07 PM
Dily-D's Avatar
Default ata 250e toa toa
Hello, I just got a toa toa ata 250e and was wondering what quick upgrades I can do to make the quad run better like what ngk model spark plug to swithch over to. also how long would it take before the fan kicks in as I ran it at a stand still for 10 min with no fan action, I tested the fan and it works so maybe its a faulty sensor or 10 min is not a long enough time? I also changed the batery that helped alot. It is bogging down at half throttle even with tires lifted off ground it may be the plug I put good gas in. any info would be very much apreciated
Old Aug 2, 2010 | 10:11 PM
Dily-D's Avatar
is there a web page that has a owners manual for the toa toa ata 250e?
Old Aug 2, 2010 | 10:15 PM
Jaster94's Avatar
NGK Spark Plugs USA
that's the NGK application charts, click through to select and narrow down, then the little red "x" is selectable and it'll take you to the selected plug.
Old Aug 3, 2010 | 08:46 AM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
Welcome to the forum Dily-D!
NGK D8ES
No idea on the fan...the only quad I have with a fan on it turns by a switch.
Old Aug 3, 2010 | 06:52 PM
Dily-D's Avatar
Default ata 250e running too rich?
Hello, thanks for the info on the spark plug. I put a new one in and it ran better but after 10min of run time I checked the plug and it was black again! what does this mean? and please how can I adjust or fix this? I hope its not a seal inside, maybe because I tuned the screw on the carb (I think) right after the air filter to try and find a sweet spot at idle. any info on all possible causes for a new plug to turn black and info on how to correct please
Old Aug 3, 2010 | 08:18 PM
Jaster94's Avatar
it's running rich. needs to be adjusted on the mixture screw to lean it up a little bit. read the sticky thread on the chinese quads forum to get the scoop.
Wooodyii2
Nov 16, 2020 07:14 PM
Chandlerksymonds
Nov 25, 2014 02:44 AM
dwardfa
Aug 19, 2014 04:29 PM
tparsons
ATC 3-Wheelers
Jun 22, 2007 10:09 PM
