gionanii 110 atv
Old Aug 20, 2010 | 06:02 PM
brianhare's Avatar
Default gionanii 110 atv
i got a wiring diagram off your web site. looking for the ohms for the stater, not sure if its charging or not?? any other ideas for the charging system??? thanks for your time...
D
Old Aug 21, 2010 | 12:03 AM
LynnEdwards's Avatar
Electrical Expert
Start up the quad with the headlights off. Rev the engine up to 3000 RPM or so.
Measure the battery voltage with a meter. Put the probes right on the battery terminals. What do you measure?
If you measure 13.5 to 14.5 volts DC your charging system is working.
If the voltage doesn't fall within that range then report back and we can go from there.
