110 atv wont start
Old Sep 2, 2010 | 08:38 PM
garrye's Avatar
Default 110 atv wont start
i need help 4 my sons 4wheeler it wont start it makes a clicking sound ,i got a new starter 4 it and still doing the same thing
Old Sep 20, 2010 | 09:12 PM
Lockman0075's Avatar
Have you tried replacing the battery? I just went through the same thing. The battery showed 100% charged but all it did was click (starter solenoid engaging) I replaced the battery and it fired right up. Also test the starter that you just replaced. I have got bad ones before. Luckily I have a shop that deals with chinese quads close by.
Old Sep 20, 2010 | 09:31 PM
Jaster94's Avatar
load check/test battery--replace if necessary, jump solenoid to verify key/start button operation, check fuses. if the starter is out on the ground. test it. check all electrical connections. battery to leads, solenoid terminals, terminals on starter. and last of all, ground wires. make sure acid levels are fine in battery. please don't get in a rush & buy all kinds of parts, if your car doesn't start, do you buy starters or check out the battery first? yep, start with the simple stuff: battery, fuses, wires to/from etc.... atvs are no different. holler back at us.
Old Sep 20, 2010 | 10:11 PM
LynnEdwards's Avatar
Electrical Expert
Good advice above.
Another thing you could try: Use jumper cables to jump the quad battery to your car (be extra careful to get the polarity right - Plus to Plus and Minus to Minus).
If your battery is duff then the starter will crank fine with jumper cables in place.
Old Oct 4, 2010 | 11:32 PM
Electrical Expert
Originally Posted by OutsideDistributing
Prices are not listed on this site to the general public but are available from authorized dealers.
Now why does that make me think these guys are horribly expensive?
Go to walmart. Any 12 volt battery that fits is fine.
Jeez...
MikeyBoyesq
Nov 27, 2020 02:44 PM
Mkp
Mar 28, 2020 03:50 AM
tiresharkdbb
Sep 3, 2017 02:06 AM
garyt1975
Jun 5, 2015 08:53 AM
1000gade
May 27, 2015 12:37 PM
