need help with my 200cc GIO beast motor!!
Old Sep 30, 2010 | 07:43 AM
man_of_koRn18's Avatar
Default need help with my 200cc GIO beast motor!!
Hey, im having sum trouble with my GIO beast motor, i rode my beast till it died then stupidly literaly CUT the motor out of the frame and tossed out all the electrical . and now i have recently fixed what was wrong with the motor and started to make a go kart with the motor and wheels ...ect, the conector is gone off the wires from the stator and i need sum help wireing it up so it will run again, if anyone has any ideas bout if i need the CDI or rectifier for it to run or how to help me out let me know A.S.A.P. thx
Old Sep 30, 2010 | 11:13 PM
LynnEdwards's Avatar
Electrical Expert
Yes, of course you need all that stuff.
1) You'll need a Battery, in line fuse, CDI, kill switch, coil, and a starter solenoid to get the thing to start up with a screwdriver short across the solenoid.
2) You'll need a regulator to keep the battery charged up, heat the auto choke into running at normal air/fuel ratios (if you have an autochoke), power the fans (if your quad is liquid cooled), and run any lights.
3) Finally you will need a start button to start up the quad normally with a switch instead of a screwdriver.
This is a fairly big job. That is why I divided it into 3 projects above so you can tackle one at a time. There is no sense worrying about project 2 or 3 if you can't get the quad to start in project 1. You'll need lots of wire, soldering skills, and a meter. You up to this?
How many wires are coming out of your stator? What are the colors?
EIF
Apr 20, 2017 07:15 PM
mrtidy
Feb 3, 2016 05:00 PM
kodiacrunner
Oct 4, 2015 11:52 AM
Whitelx1
Oct 2, 2015 10:55 PM
maveikfe
1) Engine problems..
Sep 24, 2015 10:36 PM
