Remote kill rewire
Old Oct 1, 2010 | 12:54 PM
Popeye31's Avatar
Default Remote kill rewire
I picked up a Kazuma at least I think its a kazuma out the trash. every thing was there but the remote box. the guy had the tether wires in the tail light and the tailght in the tether.the starter was off and the stator cover was off. I moved some wires around and can get the start button to work but the remote kill box was not there just the key fob and looks like the alarm horn. what wires on the plug that plugs into the remote box do I need to jump to get this thing started. it has a 6 wire plug I want to make sure it runs before I spend the $40 bucks on the remote .I checked the cdi box with my oldeset sons mini rice bike and it works fine. will check the regulator today. My other son the one I picked the bike up for is so excited to hear it run he cried last night when I told him we need to wate a little longer till I figuered out the wires. got to love them little ones. does any one have a wire diagram for the bike. I can trace the wires to the cdi box and regulator but when they come out I dont know what wire goes where. Thanks
Old Oct 1, 2010 | 09:15 PM
Popeye31's Avatar
I got good spark need compression numbers
Old Oct 1, 2010 | 11:07 PM
Mr.Firemouth's Avatar
For the wires shoot some pics, it will help alot.
For the CDI wiring, the black red is AC power lead. The Black/white is the CDI kill wire.
The Black/yellow will go to the coil.
For the remote kill switch/alarm box most people are removing them as they tend to cause problems with cutting out the spark. This is probably what the old owner was having problems with too. If you can wire the quad to run with out it then you should do that unless you really want the use of the remote.
We can help more if we can see what you have in front of you. Pics will help.
Old Oct 2, 2010 | 09:40 AM
Popeye31's Avatar
I figured it out.
EIF
Apr 20, 2017 07:15 PM
NRA+1
1) Engine problems..
10
Sep 20, 2015 08:47 PM
alzgarvin
Sep 11, 2015 08:53 AM
GODsRebel
11
Sep 8, 2015 12:07 AM
toonces
Sep 5, 2015 01:14 PM
