250cc Chinese ATV. Unusual sound when starting.
Old Oct 7, 2010 | 09:13 PM
Mr.Firemouth's Avatar
Awesome! Let us know how the fine tuning goes!
Old Nov 20, 2023 | 07:15 PM
Hoferpeh's Avatar
Question
Hello everybody. First time on here. Got this 2007 Chinese 250cc 4 stroke quad. Starter struggles or even stops spin completely. Release starter button, spin again, will start, but starter struggles a lot. Engine runs perfect. So far, new starter, new battery, new woodruff key, valve gap reset, new oil, exhaust not plugged, wiring all tight. does the same thing when jump the starter solenoid. Put on a jumper cable from car battery to ATV, same thing. i cant figure this out for the life of me. any help would be greatly appreciated, tks
Old Nov 21, 2023 | 03:32 AM
If the starter clutch slips, it is most likely to do so just before TDC on the compression stroke, which is exactly when the plug fires, so the engine tries to run backwards, starter still trying to force it forwards. I have also had a Suzuki doing this when the starter idler gear bearing had failed. If it spins over better with the plug disconnected, then this is happening.
Old Nov 21, 2023 | 11:51 AM
Hoferpeh's Avatar
thank you, i will replace the clutch. cheap enough. Also, will let you know if that worked, tks
Old Nov 21, 2023 | 11:55 AM
  #15
Hoferpeh's Avatar
Thumbs up
Seems the starter completely stops or locks. Would i be hearing any starter sound or any other sound when trying to spin?
PS, the engine does make a funny click noise just when this happens. That could be the clutch slipping. Whats your thoughts?
Old Nov 23, 2023 | 02:42 AM
  #16
As I wrote above, take the plug lead off and see if that allows it to spin any better. However, it could be a bad connection on a thick lead, either battery to solenoid to starter, or battery to earths on engine or frame, so check all of them too.
Old Nov 29, 2023 | 09:28 AM
  #17
Hoferpeh's Avatar
new clutch assy, same thing.
Old Nov 30, 2023 | 04:12 AM
  #18
Did you try spinning it over with the plug lead off?
Old Nov 30, 2023 | 09:29 AM
  #19
Hoferpeh's Avatar
Yes, works 100%. I even tried, with the plug wire off, turned the engine with starter, spins as expected, plug lead wire onto plug, stops instantly. works the starter button back and forth a few time. Starts and runs perfect.
Old Dec 1, 2023 | 02:54 AM
  #20
Right, so ignition timing is over-advanced, or something is jamming up under load, such as the idler gear for the starter if it has one. You checked the flywheel key, but is the trigger coil mounted correctly? The trigger coil and the CDI's electronics control when the spark occurs so, if it is over-advanced, it is one of these at fault. I have heard that connecting the trigger coil backwards can alter timing, if it has two wires from trigger to CDI, it may be an idea to swap them round and see if it makes any difference.
RickRitter
Jul 26, 2007 10:43 PM
TriplxX07
Apr 23, 2007 04:15 PM
raptorider660
Aug 26, 2005 05:48 PM
fidge1
Jul 27, 2004 09:37 PM
warrior68man
May 16, 2004 09:09 PM
