Kazuma 250cc no power
Old Oct 16, 2010 | 10:27 AM
familymud's Avatar
Default Kazuma 250cc no power
The quad will start first try and can idel for hours fine. On flat land it will move ( feels theres missing power ) but under any load ( slight hills ) it spudders and wont move just buck like its trying. sometimes it will stahl but if you let it sit for a few min. it will start right up. I have had problems with it doing the same things before and when i would change the CDI it would be fine for awhile . i Have replaced the CDI many times. I'm wondering now if i have been over looking the real problem. I tryed replacing the CDI with a proformance one and it wont even start. I put a new cheap replacment in it and it started up. Not sure if that helps. Any ideas would be great thanks
Old Oct 16, 2010 | 11:31 AM
familymud's Avatar
Just alittle note : i had the quad running for over an hour at an idel. I got on it and opened it up it ran fine for a few min. then the power loss started untill it just died.
Old Oct 16, 2010 | 11:40 AM
edrizzo's Avatar
try adjusting the float on carb (maybe running out of fuel)
Old Oct 16, 2010 | 04:35 PM
familymud's Avatar
found the problem jelly-crap in fuel lines and carb. cleaned and cleared running fine. so many CDI problems i lost track of the basic stuff to check
MeadowlarkFarm
Nov 27, 2019 08:40 PM
bvolks
Sep 13, 2015 12:57 PM
MeadowlarkFarm
Sep 9, 2015 03:08 AM
byronman
Sep 6, 2015 06:34 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
