how to adjust the carbs on a D1E41QMB 50cc 2 stroke
Old Feb 28, 2011 | 09:43 AM
nosparkbandit's Avatar
Default how to adjust the carbs on a D1E41QMB 50cc 2 stroke
I have come to realize the new coil I ordered was BAD so after many hours of posting and testing and ohming I Finally got the 2nd new coil I ordered. Now with new coil #2 installed low and frickin behold I have spark.
Houston we have yet another problem.
Will fire and idle with choke on. If I give it throttle it dies if i push choke lever in it dies.
I CAREFULLY took the carb apart and amazingly it was very clean inside. I removed the needle and seat cleaned with carb cleaner also removed and cleaned the idle and fuel screws. I cleaned the body of the carb itself and then reassembled.
I tried to adjust carb according to other posts that I found but cant get it right or I'm missing something.
Any help would be greatly appreciated.
kelleycully
Sep 15, 2016 02:57 AM
Ramman1
Jun 16, 2016 09:07 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
Jul 7, 2015 11:00 PM
