sunl questions
Old Apr 23, 2011 | 09:11 AM
sickshaun's Avatar
Cool sunl questions
hello new to board i have a few questions regarding a sunl 150 quad.My neice just bought it and the head light's were cut off(the harness)the previous owner had bypassed the kill switch etc.after rewiring the head lights back into the harness plug they dont really work one comes on in high beam(not bright at all) and in low they both glow just alittle.but when i push the start button while its on they get brighter..? any ideas..also where is the I D plates on the frame located and do you have to register them with DMV.all i can find is a engine I D #? Also can you change the exhaust on it ..
Old Apr 23, 2011 | 09:29 PM
LynnEdwards's Avatar
Electrical Expert
Originally Posted by sickshaun
...after rewiring the head lights back into the harness plug they dont really work one comes on in high beam(not bright at all) and in low they both glow just alittle.but when i push the start button while its on they get brighter..? any ideas...
Check the DC voltage at each headlight wire with a meter. Use the battery minus terminal for the meter black lead, use the meter red lead to probe the headlight wires. When the ignition switch is on you should have solid 12 volts at the low beam pin when low beams are switched on, and solid 12 volts at the high beam pin when the high beam are on.
But that only tests the 12 volt supply side which only half the electrical current path. Now repeat the tests above but put the meter black lead on the headlight ground wire instead. You should still get a solid 12 volts. If you don't have 12 volts then you have a bad ground return path.
...also where is the I D plates on the frame located and do you have to register them with DMV.all i can find is a engine I D ....
My quad has a VIN number stamped on the frame. Left side toward the very front of the main frame. You have to look close to see it.
In California you have to register everything. Well, not quite.... I don't have to register (and smog test ) my lawn mower yet, but there is a big push in the state legislature to do just that. I don't know what state you are in - you'll have to check your local laws...
Old Apr 23, 2011 | 11:01 PM
sickshaun's Avatar
thank you i was goin to try that.yeah im in california and i hope your kiddin bout the lawn mower even though it dont suprise me..i looked on the frame every where and could not find any id or a place a tag might have been at one time.
Old Apr 24, 2011 | 10:22 PM
Electrical Expert
I'm worried for you... No VIN number, no pink slip, no prior registration... And the infamous california DMV. I've had really bad experiences with the DMV even when I am trying to everything by the book.
Whatever you do, cooperate. Don't try and mess with them. They have absolutely no sense of humor. When I tried to register my new Harbor Freight trailer a few years ago we got bogged down at the DMV window (after an hour + wait) over what kind of trailer it was. What do they mean what kind of trailer? Apparently "its a trailer trailer" isn't good enough, and they were not going to help me out with finding acceptable answers. I had to write something in the blank space, and after getting mad I wrote down "portable meth lab" (I was joking of course). They didn't think it was funny, and I had to have the local police come out to my house, inspect and sign off my new trailer (for a substantial fee). And then, according to the DMV, the police didn't fill out the inspection form properly, so I had to have them come out a second time (and a second fee).
It is a "flat bed" trailer BTW. As compared to what I don't know, but "flat bed" trailer works...
OK, maybe I deserved that one... I have a lot more california DMV stories, but I'm off topic enough...
Let us know how you do. I hope it goes well...
Alex G.
Sep 11, 2017 11:38 PM
EIF
Apr 20, 2017 07:15 PM
Ahtatu
Sep 28, 2015 12:14 PM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
