14tooth to 12 tooth
Old May 1, 2011 | 02:33 PM
ssssthomas's Avatar
Default 14tooth to 12 tooth
If i change my sprocket to get more power will i have to shorten my chain?
Old May 7, 2011 | 12:58 AM
Mainstreet's Avatar
Yes, you will need to shorten the chain. Please note that some models also encounter issues with the clearance between the chain and the swingarm when performing this swap. Make certain the chain will clear the swingarm at a lower position (a 12t sprocket will be considerably smaller in diameter), and you may also want to order a half link to ensure adequate adjustment. Most 12T sprockets will also require a modification to your existing retaining ring to keep it in place, but this is an easy task to complete. We would be happy to assist you in ordering the correct parts if needed, we have a large selection of parts for Chinese products.
Old May 7, 2011 | 04:57 AM
ssssthomas's Avatar
thanks. how exactly do i shorten the chain?
Old May 7, 2011 | 12:51 PM
Mainstreet's Avatar
Assuming you do not have a chain breaker, you can grind away the head of the pin that links your chain together, then separate the link to remove the unused portion.
Here's a link to a video showing you the procedure, it definitely lacks professionalism but will point you in the right direction ...
YouTube - How to remove a link out of a chain
Good luck !
Polarisman1123
May 25, 2015 10:07 PM
Polarisman1123
May 25, 2015 10:03 PM
NewDSLover
Mar 7, 2001 02:47 PM
THEXOTIC1
Jun 23, 2000 05:02 PM
bigmanm
Mar 19, 2000 01:37 AM
