110 cc ATV no start
Old May 15, 2011 | 03:52 PM
fingerz's Avatar
Default 110 cc ATV no start
Turns over fine, has spark and is getting fuel but will not fire. I did a clean on the carb but still no go. Long story short who ever assembled the bike had mounted the ground wire to the crank case and stripped the bolt that they used so it came loose. Then we started having problems starting it and that's when I noticed that the bolt holding the ground was loose and striped because I seen sparks. I re-grounded the wire properly and ever since it will not start yet we have spark and fuel. Anybody have any ideas.
Old May 15, 2011 | 06:40 PM
Mainstreet's Avatar
Are you getting a good spark from the boot or the plug itself? If it still has a Chinese plug, try switching to an NGK CR7HSA.
If you are sure fuel is getting to the cylinder but it still won't start, you may want to check your compression or take a look at your valve lash. If you're not sure the fuel is making it into the cylinder, you could always try putting a small amount in there to see if it will start that way.
Old May 17, 2011 | 02:13 PM
markhasparts's Avatar
Default when you get it figured out...remember markhasparts!
when you get it figured out...just remember Markhasparts!
MikeyBoyesq
Nov 27, 2020 02:44 PM
Mkp
Mar 28, 2020 03:50 AM
tiresharkdbb
Sep 3, 2017 02:06 AM
garyt1975
Jun 5, 2015 08:53 AM
1000gade
May 27, 2015 12:37 PM
