90cc ATV won't start
Old Jun 2, 2011 | 01:54 PM
jim103's Avatar
Default 90cc ATV won't start
I have an Xtreme Machine 90cc atv that won't start. Getting good spark, carb in clean, fresh gas and oil. Every now and then it sounds like it wants to pop but doesn't. How much compression should these have? Could it be a timing issue? Any help would be great. Thanks
Old Jun 5, 2011 | 09:46 PM
Mainstreet's Avatar
Based on your symptoms, it sounds like valves. Bring it around to TDC and make sure they are set correctly. If your engine is the E22 style, it should at least start with anything above 80 psi.
Old Aug 7, 2011 | 06:54 PM
Rogen's Avatar
I just had this same problem with my son's 90cc Extreme today. If your unit has an electric choke (located on the top of the carburetor), unplug the black connector. This worked for me.
You may have to let it crank over for a minute, but then it should run fine.
Hope this works for you
MikeyBoyesq
Nov 27, 2020 02:44 PM
Bigredjeep
Aug 24, 2015 12:27 PM
1000gade
May 27, 2015 12:37 PM
mrdci
Dec 4, 1999 11:03 PM
hot_shoe_cv
Oct 13, 1999 02:16 PM
