Question about the Electrical system after the engine is started
Old Jul 10, 2011 | 10:29 PM
King_Loco's Avatar
Exclamation Question about the Electrical system after the engine is started
Not quite sure if it was coincidental or not but it appeared that once I took the wires off of the battery after I got it started, the engine would die? But I do remember taking the wires off and the engine was running fine so that may eliminate this question. I just wanted to ensure if I was one hundred percent sure that the engine was running when I disconnected the wires from the battery.
Normally, once you get the engine started, the electrical system should have nothing to do with it thereafter. Am I mistaken?
My overall diagnosis is that I should charge up all of my batteries using a battery charger then continue to crank the engine since it seems like its just trying to shoot some of the crap out since it has been sitting for a while.
Old Jul 19, 2011 | 03:08 PM
Jaster94's Avatar
i don't run a quad without a battery being connected. dead or alive. i believe the circuit would be incomplete. it'd be possible to burn something up. you can have a dead battery and pull the ripcord and it'll start. at least that's been my experience. the real experts can give you more detail.
SOLOLUCKY
Oct 4, 2024 09:09 PM
MikeyBoyesq
Nov 27, 2020 02:44 PM
EZRyde
EZ Ryde Exhaust
Jul 30, 2015 12:46 PM
generalpops
Jun 5, 2015 08:23 PM
1000gade
May 27, 2015 12:37 PM
