Engine stalls when throttle is released
Old Jul 24, 2011 | 06:46 PM
chrisdisam's Avatar
Question Engine stalls when throttle is released
We bought an ATA110-B model ATV for our 6 yr old daughter. We took it out in the back yard to get her started and noticed everytime she let off the throttle, the engine stalled. I had some people (not proffessionals) look at it and said it was probably just a safety feature. Not real familiar with and was hoping for some advice/guidance.
Old Aug 2, 2011 | 09:30 PM
Jaster94's Avatar
how low is the idle? just guess at RPMs....does it sound like it barely putts or is it fairly smooth at idle? if the idle screw is set too low, then raise the idle up. but if the screw is set out pretty good, you may need to clean the pilot jet in the carb..OR, check the throttle cable, unsure if that one has a throttle control like a polaris..... as far as shutdowns....
skinnyr6
Aug 25, 2023 02:18 AM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
MNatv89
Jul 7, 2015 11:36 AM
Riding Gear
Jul 7, 2015 05:03 AM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
